Question about Kenmore Refrigerators
I am getting condensation in the refrig. - Kenmore Refrigerators
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore refrigerator isn't getting cold enough
SHORT OF GAS,OR WEAK COMPRESSOR. NEED ENGINEER.
Mar 09, 2010 | Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
I get a puddle of water inside of the the refrig every a couple days, I have turn off the refrig, and blow with the fan for over 5 hours, hoping that will solve the issue, however that didn't work.
check the seals for leaks. condensation from warm air leaking into the fridge through bad seals collects on the inside. also, if condensation collects on the evaporator coils, it'll freeze. then when it goes into defrost mode, all of the frost and ice melts into a condensate pan under the fridge. if the tube to the pan is blocked, the condensate stays in the fridge. so, check the seals and check the condensate tube.
Nov 09, 2009 | Samsung RS2630SH Side by Side Refrigerator
Stopping condensation inside refrig.
Condensation occurs when air is entering the refrigerator. There is moisture in air and the when the air gets in the cool refrigerator temp condenses the moisture in the air into water. So basically you have a gasket that is not sealing or one of the doors is not completely closing, or possibly it could be from constant opening and closing in a large family or kids getting stuff in and out all the time.
Sep 10, 2009 | Kenmore Refrigerators
GE TBF19ZB won't cool. Motor is running, But, refrigerator and freezer are not getting cold enough. Refrigerator and freezer are set at middle settings
dirty condenser coils or condenser fan not working most common problems,condenser is at bottom of refrig. next to compressor.
Sep 07, 2009 | GE Refrigerators
My magic chef refrig. gets hot on the outside
Make sure the condenser fan underneath the unit is running and make sure the condenser coils near there are clean. Remove the cardboard back to access.
Jul 01, 2009 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
