Question about Norelco 7886XL Electric Shaver
Need battery replaced. Is there a service center close to Derby, Kansas
  • Norelco Master
  • 1,602 Answers
You will have to look in your local phone directory to fin a local repair shop. If you can't get it one locally, shaveroutlet.com will do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Sep 09, 2010
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
Clutch is slipping on my 2008 flhx how do [ adjust clutch beyond adjustment in cable
take all slack out of cable . take derby cover off loosin lock nut in center if pack tighten addj screw turn in till seats back out 1/2 to 1 turn tighten lock nut . take slack out of cable . hatleytalking.con ...good luck
Oct 29, 2011 | 2008 Harley Davidson FLHX Street Glide
How do I replace starter on 2002 sportster
First disconnect the battery cable. Then you'll have to pull the primary cover off the engine. Find the primary case drain plug underneath the rear of the primary case and remove it to drain the oil. Find the primary chain tensioner underneath the primary cover near the center and loosen the locknut. Turn the screw downwards to loosen the tension on the primary chain. Remove the left foot peg and take the "derby cover" off of the primary cover. Remove the spring and lock nut underneath the derby cover. Remove the bolts around the primary cover. As you gently pull the primary cover away from the engine, turn the clutch adjuster screw under the derby cover in a clockwise direction until the primary cover comes off. Remove the battery cable where it bolts onto the starter motor and the small single wire that plugs to the motor. Just above the clutch assembly there are two bolts. Remove these bolts and the starter will come off the engine. The bolts are different lengths. Make sure you mark which bolt goes where.
Good Luck
Steve
Sep 05, 2011 | Harley Davidson XL 883 Sportster...
What is the clutch adjustment for 2003 HD Electric Glide Classic
To adjust the clutch, follow the clutch cable until you find the cable adjuster. Move the adjuster cover up or down to expose the adjuster. Loosen the lock nut and adjust the adjuster to get as much slack as possible.
Now, remove the derby cover. Loosen the locknut in center of the clutch assembly. Turn the center bolt inwards until you feel a resistance. Do not force the bolt, just turn it inward until you feel a resistance. Then back the bolt back out 1/2 turn and lock the locknut. Replace the derby cover.
Now, go back to the cable adjuster and adjust it back out until you have about 1/8" freeplay. Squeeze the clutch lever a few times and recheck the freeplay. Lock the locknut and replace the cover.
Good Luck
Steve
Jan 10, 2011 | Harley Davidson FLHTC Electra Glide...
I Need to adjust My clutch on 2005 Harley,Touring Bike
To adjust the clutch on your ultra, first find the clutch cable and follow it down until you find the rubber bellows cover over the clutch cable adjuster. Move the cover out of the way and loosen the locknut. Turn the cable adjuster inward to get as much slack as possible in the cable.
Now, remove the derby cover. In the center of the clutch assembly, you'll see an adjuster screw and locknut. Loosen the locknut. Turn the center screw inwards until you feel a resistance. Do not force the screw. Turn it inwards until you feel the resistance. Then back it back out 1/2 turn and lock the locknut. Replace the derby cover.
Go back to the cable adjuster and adjust it outwards until you have an 1/8" freeplay at the hand lever. Lock the locknut, replace the cover. You may have to tweak the adjuster just bit to get the engage point exactly where you want it.
Good Luck
Steve
Sep 12, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
Where in kansas city to get my shureE5 repaired
The only Shure Service Center in the U.S. is at the factory. Information on repairing your earphones can be found at www.shure.com/service
Nov 14, 2009 | Shure E5 Professional Headphones
Help
Call Bissell at:Service Center Dept. Phone Number:
(800) 457-1509
They will give tell you where you can take yours to for repair.
Oct 31, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Norelco 7886XL Electric Shaver Logo
47 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
