Question about Brother LS-2125 Mechanical Sewing Machine
The small button (which I was to use to correct the tension when making a button whole) which is the right of the button used to pick a stich (1-10) fell into my macine. Is there any way to open the machine to get it out. I've tried shaking the machine and I can hear it rattling around but it hasn't fallen out. Thanks much.
    Genius:
  • 1,788 Answers
Did you open your bobbin case and check? How about calling Brother at 1-877-276-8437, they are there until 5:45pm est
Posted on Sep 08, 2010
I need to put bobin in place but Nedle dosent take the tread up
Make sure you are using a brand new needle and that is inserted correctly (there is right & wrong way!).
If it still will not pick up the bobbin thread, most likely the needle/hook timing is off. Take it for service.
Aug 09, 2016 | Sewing Machines
Singer 328 is not stiching
if upper thread correct, check bobbin is wound and inserted correctly. Pulling bobbin thread, the bobbin should turn counter clockwise. make sure thread is under bobbin case tension spring. With cover plate open hold needle thread and turn hand wheel towards you to see if hook picks up needle thread and passes it around bobbin case. if not check hook timing
Jan 05, 2014 | Sewing Machines
Tension setting for small straight stitch on a Kenmore 10 Stich model 385 1249380 sewing machine.
Please go to Kenmore model 385 1249380 sewing machine sell shop and ask the machanic or shopkeeper.
Jan 01, 2014 | Sewing Machines
Top thread keeps breaking during sewing. Tension adjustment does not solve the issue. Also, machine is skipping stiches and will not sew anything but a straight stitch: needle moves in the ziz=zag or...
This could be more than one issue, first I don't think you have the machine threaded correctly. Make sure when you thread that the thread is seated betweeen the tension disc on the top and also, make sure that you have properly but tin the bobin
Aug 13, 2010 | Husqvarna Sewing Machines
My stiches are tight and small
Either the stitch length selector is not working, the feed dogs are not working, or the tension is too tight.
Check the manual for your sewing machine for the correct tension setting.
Thread the machine with the presser foot up - always.
Check the settings for the length and see if it changes when you change the setting.
Check the feed dogs to make sure they are engaged/up.
Never use thread for hand quilting or buttons as they both have a coating which can gum up the tension.
Keep the machine clean and lubricated (if this is indicated in your manual - some of the new models require this be done by a service tech).
Feb 23, 2010 | Sewing Machines
Vintage machine I can't get to work properly
Humor me and unthread your machine completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn't pass this test Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Mar 19, 2009 | Sewing Machines
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
L-344 loose stiching
You need to do a tension assembly test. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Dec 22, 2008 | Janome L-344 Mechanical Sewing Machine
JANOME MEMORY CRAFT 8000 - TENSION
You need to do the following:
If it still messes up ,remove the bobbin case and examine it for burrs or scratches. Remove them with and emery stick and fine steel wool.
sewman7
Nov 04, 2008 | Janome Memory Craft 5700
Brother LS-2125 Mechanical Sewing Machine Logo
54 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
