Question about Casio ClassPad 300 Calculator
Hi, I have a Casio Classpad 330 and I have problem with my touch screen. There is nothing happened when i tapping on the screen, but the keyboard is working properly. It seems it is damaged or corrupted. Do you know how can i fix this problem? Thanks
  • pe_civ2002
    pe_civ2002 Apr 10, 2013
    I have the same problem.i can select the right points of startup.and can't get to main menu or connect it to PC
I can give you the following suggestion.
The touchscreen will recognize your
stylus tapping if you simultaneously
have any of the keyboard buttons pressed (except 'Clear').
Once you see the whole menu (after screen
calibration and brightness settings) press
Clear than Exe than Clear and the screen
should be touch sensitive again.
Hope this helps.
Posted on Nov 06, 2010
I have same problem, and was searching in enternet and read some solution, but not found any way to fix my problem.
Please help me.
Posted on May 05, 2011
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Casio classpad 330 isn't square rooting
Select Main Menu. At the top left of the screen tap the down pointing arrow, select Settings, then SetUp, then Basic Format.
Check the Decimal calculation box.
Nov 05, 2012 | Casio ClassPad 300 Calculator
How can you calculate "atan" on the classpad 300?
In Main screen press the keyboard button.Tap the Trig tab at the bottom left. tap the function tan^-1.
Nov 12, 2011 | Casio ClassPad 300 Calculator
How do I enter degrees minutes seconds on casio classpad 330
This is valid for the ClassPad 300Plus (OS version 2.2) but it should work for the ClassPad 330 OS version 3.x
In the MAIN menu screen press the Action menu, then Transformation sub menu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
May 12, 2011 | Casio ClassPad 300 Calculator
How do i enter a degrees/minutes/seconds value on a casio classpad 330
Jan 30, 2011 | Casio ClassPad 300 Calculator
How do i enter degrees minutes seconds on classpad 330?
Sep 06, 2010 | Casio ClassPad 300 Calculator
I dont know how to do a Trig problem on my classpad 330
Press the keyboard button to display the soft keyboard on screen. By default it will show the tabs mth abc cat 2D
Tap the TRIG tab at the bottom of soft keyboard. The trigonometric functions will become available to you.
To make sure you are using the correct angle units look at the bottom of screen where it says Alg Standard Real Rad. If you use degrees instead of Rad it should display Deg.
To set the correct angle unit, press the Setting icon at the lowest left of screen and choose radian or degree and select decimal calculation if you need evaluated decimal results. Tap the set button to validate your choices.
Jun 16, 2010 | Casio ClassPad 300 Calculator
How to do binary,hex BCD and decimal on casio classpad 330
to convert between bases, go to keyboard, then cat(alog) and press B to scroll down to baseConvert(
syntax: baseConvert(value to change, original base, new base)
e.g. to convert 1100 from binary to decimal
baseConvert(1100,2,10)
Sep 14, 2009 | Casio ClassPad 300 Calculator
Replace Casio Classpad Touch Screen Protector
Th ClassPad has a touch screen and a plastic cover to protect the touch screen. If we are talking about the plastic cover you can sure remove it by sticking one end of a piece of non smudging tape near the corner and pulling up gently on the other end. Do not throw it away.
Actually, many people do remove the protective plastic claiming rightly or wrongly that screen reflection is diminished. It is up to you.
Hope it helps.
Mar 25, 2008 | Casio ClassPad 300 Calculator
Casio ClassPad 300 Calculator Logo
2,804 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
