Question about Hoover Washing Machines
Hoover SE220 washing machine. Poor results & a few bits of powder remaining in clothes - looks like water is not heating. The machine completes cycle ok but tried a 90 degree wash with machine empty. Stopped the machine just before the timer clicked round to the next (60 degree) programme and the water in the drum was stone cold. At the time my hot water was turned off so only cold water was coming through the hot water supply. Thermostat not working? Andrew Pugh
  • Hoover Master
  • 3,899 Answers
Its more likely to be the heater element the temp sensor is fitted to this, remove the rear of the unit and at the bottom of the back of the drum there is a nut and either side there are 2 wires remove them and undo the nuts first nut holds the earth second nut remove but not all the way, un clip the connector for the thermostat, with all wires out of the way now push on the nut as to push into the washer and then pull on the 2 parts were the wires were it will be stiff to move. when it comes out wipe around the hole and clean it before fitting new element. fitting the element in side there is a metal plate the element has to fit into this, best way to fit it right is to make the element end at an angel when fitting. when its fitted it should be flush, tighten the nut until its a nice snug fit with no movement. then refit all wires and earth wire and nut. check everything is done and looks the same as it was when you started. you are now done. put back on and washer ready to use.
Posted on Jun 05, 2017
5 Suggested Answers
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
  • 5 Answers
SOURCE: Hoover SE230 Programmer rotating
Hi there, my washing machine was doing the same as the one you have mentioned.
I bought a replacement timer from the website highlighted below. It has done the trick and every programme works properly now.
A competent DIY person can change one of these easily and will take about 30 minutes to do.
The new part looks slightly different but it carries the same part number.
The price £24.99 + £4.98 delivery.
http://www.4hoover.co.uk/cgi-bin/product.pl?PID=723224&section=46246&brand=&model=SE230&path=45786,46246
Posted on Nov 08, 2008
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
How do I remove crud from inside a washing machine?
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Dec 19, 2012 | Fisher and Paykel Washing Machines
My Simpson Ezi Sensor is washing clothes leaving grimy tracks and soap powder on the clothes. BeforeI seek any mechanical help, can I put the washing machine through a cleaning cycle of hot water to clean...
Hi from France,
Particularly if the water supply has a lot of calcium in it (hard water), it is necessary to 'clean' it out regularly.
This is done by buying anticalc powder sachets specificaly designed for washing machines (AND often the same stuff for dishwashers!).
If your machine is not new i.e. a few years old and has not hathe benifit of regular cleaning it will be well worthwhile spending some money on these sachets. What I have done with ours is to swith it off, put a couple of sachets into the drum and then pour in (from a kettle or similar) hot water to dissolve the powder. I have then left it overnight so that the heating element is well soaked and hopefully anti-calc'ed. Run a quick wash to flush it out. It will do no harm and hopefully improve its efficiency- IF the problem is due to poor heating and not something else.
I would start there.
Cheers,
John C
Jan 22, 2011 | Washing Machines
Is it acceptable, & obain better results with a liquid laundry soap as opposed to a powder. Specificall the new Whisk with spot removers.
Every brand will tell you , they are better, but it's up to you to decide which you like more.
There is somthing to be said for powder. It provides a firm substance to "beat" the clothes against. Yes, same as beating them on a rock but with detergant and enzymes added to break down oils and proteins.
Of course, there is always a residual dust (if you will) of the peanut shell powder base. remaining in the clothing fibers.
Liquids detergent leaves less residue behind but lacks the solidity of the peanut shells, therefore depends on it's ability desolve dirt etc often more effeciently than powders.
You need to try different brands and types on your own "normal" wash loads, and decide which result you like better. Of course detergents and enyme chemistry has improved a good deal in last few years.
Jan 13, 2011 | Whirlpool Washing Machines
We have a Whirlpool WFS1071BD. We are on tank water (rain water), with resultant poor pressure. We're finding our washing is increasingly smelly (mould?). Is there anything we can do/put through to make it...
epsom salts are the only thing that makes a difference tried all the new gear doesnt work as good as epsom salts every two weeks 1/2 cup on hot wash with no clothes & use cold power advanced washing powder this is the best way of keeping control of it once you get it clean you have to keep on top of it the smell doesnt take long to come back with out continues treatment.
Jan 10, 2011 | Whirlpool Washing Machines
White marks on my clothes.
Are you using TOO much powder? And is the machine set to the correct rinse tempature? You mention white stuff, does it look like undissolved washing powder? Or fabric softner? Possibly try liquid detergent and see if the problem continues. And follow the recommended amounts of detergent for each wash load, and the tempature settings. And of course the water levels. All of the above are crucial to insure you get maximum preformance and utility out of your machine, with the results you expect. Let us know what you find. Kindest Regards, Slats.
Sep 26, 2009 | Washing Machines
The soap in the washing machine is not dissolving completely, often leaving white marks on clothes and lumpy bits of soap in tray?
Try using a liquid type detergent instead of the powder before looking for other problems. Are you using cold water for the wash?
Aug 08, 2009 | Washing Machines
LG stinks too
It is not a poor design its the way we have gone re washing clothes
Old machines washed hotter and with more additives in the powders.
Try using a good strong mix of soda crystals in hot water , pour that into the wash before you switch it on and do a hot wash without any soap powder
Use old fasioned powders for a couple of weeks and do a hot wash once a month with the soda
The constant cool washes leave body fats from the clothing inside the machine as there is no real heat to melt them and no soda in the washing powder anymore to unstick them from the surfaces .
Jun 26, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
How to clean the inside of the machine
Go to the store and buy a bottle of CLR. Run a few cycles of it (without the clothes in there, of course!). Make sure you run a few cycles of just straight water before you attempt to wash clothes. That should do it. I've also heard of people using powdered lemonade to clean the inside of dishwashers, too. Maybe try the powdered lemonade first if you're squeamish about damaging something.
May 21, 2009 | Hoover HTC243 Top Load Washer
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
Cold Water 25-May-08
I know this may seem a little silly of me to ask but have you checked the filters in the back of water valves to see if they are blocked??
May 24, 2008 | Hoover AL120 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
