Question about Vinotheque Whisperkool 8000 Wine Cooling Unit (Max Room Size = 2000 cu ft)
New Whisperkool XLT 8000 is very loud, much louder than the same model XL when it was installed 6 years ago. The installation was the same in the same spot, but I can hear the unit running throughout the house, which was not the case with the last one.
4 Suggested Answers
SOURCE: The Whisperkool 4200 unit is no longer cooling the
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
Posted on Jul 09, 2010
SOURCE: Whisperkool 4200 icing up
Hi, Bob:
Misery loves company, so I'm posting this even if it isn't in time to help you.
I had an XLT 8000 with similar problems. Vinotheque wanted to do the exchange program ($2,500+), and I was told the older aluminum coils might have leaked, and the exchange models come w/ SS coils. I was near to biting on that, when I decided to have a local refrigeration shop check it out.
Here's what they found--A MANUFACTURING DEFECT. It seems there are small copper capillary tubes that circulate the refrigerant. If they touch each other, with normal operating vibration they can wear holes in each other and the refrigerant can leak out. The leak can be very slow. According to the guy who fixed it (all for $219, and much of that was for drilling out the riveted-closed enclosure), "crossed cap tubes" is a Bush League mistake, akin to not putting oil in your car's crankcase.
I'm not saying WhisperKOOL/Vinotheque did this on purpose, knowing there would be an eventual failure and an opportunity to make another sale. But what the service guy told me was that IF the manufacturer was without scruples, a crossed cap tube would be the perfect way to take advantage of an unsuspecting customer.
My fix? Drill out the rivets, and find a local qualified service tech. Fixed in hours for $219 or in weeks with an exchange for $2,500... You choose.
Posted on Jul 14, 2010
machinetech7
  • 1344 Answers
SOURCE: my wine cooler is making a loud humming noise. It still cools fine, but you can hear it throughout the house now.
possibly the compressor is running harder due to either being low on freon or the condensor coils are dirty not letting the heat to be released causing the the compressor itself to overheat.
Posted on Sep 05, 2012
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
Whisperkool 1600 xlt developed a drip from the right fan after many years of trouble free operation. What could be causing this?
http://www.luxewinecellars.com/sites/all/files/product_downloads/whisperkool-xlt-owners-manual.pdf
i was just reading the manual for you. This make not be the exact manual But once a year you have to clean the fins, bleach the inside etc. make sure the drain hose is not blocked with goo, or deposits etc.
Oct 20, 2013 | Furniture
I would like my vtx 1300 to be a little louder. can i drill a small hole in the back of the muffler to make it louder will this work any pros or cons please
Honda mufflers typically have several baffle walls You may need a drill 14 or more inches in length to punch through enough of these walls to make a noticeable difference. Changing the back pressure of the exhaust will also lean the mixture. This may cause a bad hesitation on take off. This will happen if you change the exhaust system also. To correct the hesitation you may need to install a jet kit on a carburetor model (about $100) or install a Power Commander on a fuel injected model (about $400 plus programming). In both cases your fuel economy will go down. Your stock system has a five year warranty, should not blue like an aftermarket pipe (unless you leave the choke on too long), and have a good long service life. Unfortunately there is no easy solution for your problem. Any aftermarket system will be way to loud (especially on the freeway) and drilling may not give you the desired sound you are looking for leaving you angry and frustrated. Consider a different option, One of the best sound options I have heard was a set of stock Harley pipes adapted to a Yamaha Virago 1100. Most Harley riders change out there exhaust systems before they even ride there bikes which should offer a cheap high quality system that can be adapted to your stock headers with common automotive adapter pipes and custom build it yourself supports (a simple modification of your stock pipe support/mounts). By not damaging your stock system you can always put it back on if you do not get the desired effect.
Apr 09, 2011 | 2004 Honda VTX 1300
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Jun 30, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Honda xl 125 specs
Make Model
Honda XL 125R Paris Dakar Year
1983 Engine
Air cooled, four stroke, single cylinder, OHC, 2 valves per cylinder Capacity
124 Bore x Stroke 56.5 x 49.5 mm Compression Ratio 9.4:1 Induction
PD52 Ignition / Starting
CDI / kick Max Power
12 hp 8.7 kW @ 9000 rpm Max Torque
10 Nm @ 8000 rpm Transmission / Drive
6 Speed / chain Front Suspension
Telescopic forks Rear Suspension
Swinging arm Front Brakes
Drum Rear Brakes
Drum Front Tyre
2.75-21 Rear Tyre
4.10-18 Seat Height 840 mm Dry-Weight
109 kg Fuel Capacity
17 Litres
Feb 10, 2010 | 1983 Honda XL 125 R
Furnace sounds louder and feels stronger heat coming through???
The service technician probably installed a larger motor pulley which increases the fan speed to blow more air which results in a slight increase in duct noise which is normal.
Jan 29, 2010 | Heating & Cooling
Hi, Bob:
Sep 25, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
What type of electrical plug is used on the Whispercool 8000 or does it come ith wires that need to be "hard wired' into a box. Thanks, Ed
Thought by now you would already have the information. Electrical Requirements 110v, 20 amp dedicated circuit Below is a link to the user manual and page 14 addresses your question on electrical requirements.
Click Here=> http://vinotheque.com/docs/WK_Extreme_OM_070607.pdf
Home page below.
http://www.wineracksamerica.com/Wine_Cooling_Units/Whisperkool/extreme/ES8000.html
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 21, 2009 | Vinotheque Whisperkool 8000 Wine Cooling...
Moaning Dishwasher
I am still waiting for my response. Your site has not responed yet.
Jun 25, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Refrigerators Logo
55 people viewed this question
Top Vinotheque Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vinotheque Refrigerator Expert? Answer questions, earn points and help others
