Question about Hand Tools
Need manual/instruction for Mastercraft digital temperature reader Looking for calibrationn information as temperatures apear to be in error.
RescueTech
  • 145 Answers
SOURCE: lost instruction manual
Here ya go!
http://www.u-line.com/specs/index.cfm?a=2#a2
If this helps, please rate me!
Posted on Dec 12, 2008
  • 7 Answers
SOURCE: OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
mowerman1857
  • 389 Answers
SOURCE: 1990 Mastercraft Riding mower manual?
If you want it for the tractor as a whole, I would need the model & serial of the tractor. Look under the seat, or on the frame below the seat or on the platform where the seat mounts. It is usually one of those metalic adhesive stickers with the numbers printed on it. They seem to get knocked off or pulled off quite often but without those numbers, I have no way of looking it up for you.
If yu just need engine information, I can find that with the model and type numbers
Posted on Sep 23, 2009
Turn on over and get F31.
Hello, Janice -
There are many ovens in use today. It will help to know the make and model of your oven. You can add that information by choosing Comment and typing in the make and model of your oven
If yours is a Kenmore brand oven, the F31 error code means that the oven temperature probe has shorted out or there is a shorted sensor probe harness connection.
Sources of information + repair instructions:
https://www.shopyourway.com/questions/1068107
and
https://www.shopyourway.com/questions/1036659
If your oven is a Frigidaire gas oven, then the F31 error code also means there is shorted oven temperature sensor probe or a shorted sensor circuit.
Source of information:
https://www.shopyourway.com/m/questions/1018474
I hope you have the owner's manual for your oven. The F31 error code will probably be described in the manual.
Best wishes.
Apr 01, 2018 | Kitchen Ranges
In the Temperature display I only see "- - - -" not the temperature. What could be the problem? Thanks
Typically this is a user issue, as in not reading the manual for instructions.
This is typified by not including make and model of the unit in question, not relaying information such as if the batteries in the remote are new or need replacement, etc.
I suggest reading the operator's manual, particularly the troubleshooting section, for information regarding your issue.
If you have no manual, then contact the manufacturer and get one.
Apr 02, 2015 | Heating & Cooling
Where is the air temperature sensor for a Yamaha V Star 1300
Hi, Mike for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Star 1300 air temperature sensor location Google Search
2007 Yamaha Star 1300A Air Temperature Sensor eBay
Yamaha XVS1300A 2007 Service Manual
OEM parts for Yamaha
YAMAHA XVS1300A Owner Manual
Feb 26, 2012 | 2007 Yamaha V Star 1300 Tourer
Led status 3 trouble shooting advice
More information is needed.
Water heater is not identified.
Add a comment with more information from label on side of tank.
If you have gas water heater, then open following links to identify gas valve, and download error code diagnostic and possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
For power vent water heater with Honeywell gas valve: three flashes indicate pressure switch or blower temperature switch not working.
Typical causes appear on page 13 on manual: can be bad blower, bad switch, blocked vent, exhaust temperature too high.
http://waterheatertimer.org/pdf/Icon-gas-valve-error-codes.pdf
Sep 24, 2011 | General Electric Water Heaters
I have a ge profile side by side refrigerator model number psc25psta. The freeze is not getting cold. How do I reset the temperature.
Here is a link to the main GE Support page for your refridgerator:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PSB42YSXSS
And here is a link to the Online User's Manual with the operating instruction for it:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60558.pdf
See page 5 of the User Manual for detailed instructions on how to adjust the fridge and freezer temperatures. It reads as follows in the manual:
To change the temperature, press and release
the WARMER or COLDER button. SET will illuminate in
the display, as well as the set temperature. To change
the temperature, tap either the WARMER or COLDER
button (while SET is illuminated) until the desired
temperature is displayed. Refrigerator temperatures
can be adjusted between 34F and 47F and
the freezer temperatures can be adjusted
between 6F and +8F.
Once the desired temperature has been set,
the temperature display will clear after 10 seconds.
To display the temperature, the DISPLAY TEMP button
may be tapped.
Several adjustments may be required. Each time you
adjust controls, allow 24 hours for the refrigerator to
reach the temperature you have set.
Good luck and please comment back here and RATE 4 Thumbs Up if this was at all helpful.
Just click on the highlighted links with your mouse in order to access the information described.
If the link does not open properly, you may need to download a PDF Reader program for your computer. The best reader can be downloaded free at www.adobe.com where you just click on the DOWNLOAD ADOBE READER button on the right hand side of the page and follow the on-screen instructions.
Just comment back here if you require any further assistance, I will be pleased to assist you in any way I can.
Thank you very much.
Joe.
Feb 14, 2011 | GE Profile PSB42YSXSS Stainless Steel (252...
Washer will not start. We are getting error code F-24. The manual does not give specific information on that code. Our washer is a fairly new product.
Hi
Error F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This error appears when temperature sensor fails. It could also appear due to a failed electronic control or due to a wiring failure. Unplug the washer and remove the service panel, check the resistance of temperature sensor using a volt/ohm meter. Take out the screws at the bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, remove the wires off of the temperature sensor at the bottom front of the washer tub. Temperature sensor should give reading of about 10K ohms (10,000 ohms) of resistance (RX10 or RX1) at room temperature. If the resistance reading of sensor is fine then it is due to a wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore HE2 Plus Front Load Washer
I have an electrolux w3180 error code e04 comes upon starting a program. In the manual it states Temperature sensing device indicates temperature below -5°C (continuity fault). Is this just loose...
Hello, The "e04" error code means is an indication of a water temperature sensor error below 04'c
what it means is that there is over flow of water in the sensor reader around the wire and the sensor
what you have to do to fix up the problem is to unscrew (open)the washer then cleanup the water around and also the dirt sensor and wire and allow it to relax for some time after clean up
please the clean up DOES NOT NEED water or any form of liquid to do this just apply dry cloth for the cleaning.
Thanks
Jun 11, 2010 | Washing Machines
Mastercraft Wet Sharpener; Model No 55-3504-4
I just purchased one of these machines - also without the manual (seems to be a recurring problem with Mastercraft).
I phoned Mastercraft's toll-free number (1-800-689-9928) and they apologized and said they'd mail me a manual.
Have the model # handy, and be prepared to stay on hold for awhile (took me almost 30min the 1st try, maybe 10min the 2nd).
Hope this helps.
Oct 21, 2008 | Kitchen Appliances - Others
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Hand Tools Logo
973 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
