Microphone issue Computer: Intet Core2 CPU 6600 @ 2.40 GHz. 4 GB ram with Sigmatel Audio (on board) When pluggin in Mikd Audio Control pane comes up and I activate Microphone on Rear Panel - works fine. Then I go to Microsoft SDK 5.1 to train the speech engine - microphone switches off. I have to reset it manually but it switches off every time I start training. Have removed and reinstalled both SDK and Sigmatel audio software.
  • 9 more comments
  • leol570 Sep 09, 2010
    Ok thanks, here goes.
    Firstly I only have three sockets on the on board card, no front panel (which SigmaTel caters for.) Mike is in pink, headphones in green. When I plug these in the SigmaTel prompts me to configure the mike. On pink slot I select Mic. Looking at the Recording Control in the Levels tab I can see the Rear Mic is now selected.
    At this point I can hear all microphone input in my headphones (which I don't particularly want, but anyway it works). I can now go on and use the micorphone with skype and flightsim etc.
    Next, I go to Speech icon in control panel (by the way, I run XP SP 3). At this point the Microphone Level bar picks up voice input. The minute I start training the mic dies - the SimaTel Control Panel now shows the Recording Control as Microphone and not Rear Mic anymore. At this point I have re-configure the Jack Setup to get the mic to work again. Going back to SKD 5.1 switches it off again etc.
    So the setting jumps between Rear Mic and Microphone
    On the Advanced tab of Sigmatel Panel I have Pop-ups enabled.
    Thanks - I will kiss your feet if you can solve this
    As mentioned, I only have three sockets - blue reads Center/LFE Speaker
    Hi - I don't have Midi available. OS is XP with SP 3 thanks
    Only available default device is SigmaTel Audio
    Thanks
    cant get "microphone" setting to work with any input socket.
    Hi - I don't have Midi available. OS is XP with SP 3 thanks Only available default device is SigmaTel Audio Thanks
  • leol570 Sep 10, 2010
    thanks for your help
    This is a custom built machine and I am trying to find the chip details
    To answer your question, yes, I can change back to the input that works with immediate effect. However, taking the focus off the SDK window pauses the training. Once I have re-enabled the rear microphone (the one which works) and I click on Resume in SDK, the microphone is disabled again. So it is a vicious circle
    My Computer Details:
    OS Name Microsoft Windows XP Professional
    Version 5.1.2600 Service Pack 3 Build 2600
    OS Manufacturer Microsoft Corporation
    System Manufacturer INTEL_
    System Model D946GZIS
    System Type X86-based PC
    Processor x86 Family 6 Model 15 Stepping 6 GenuineIntel ~2397 Mhz
    BIOS Version/Date Intel Corp. TS94610J.86A.0047.2006.0911.0110, 11/09/2006
    SMBIOS Version 2.4
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume1
    Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
    Total Physical Memory 4,096.00 MB
    Available Physical Memory 2.43 GB
    Total Virtual Memory 2.00 GB
    Available Virtual Memory 1.91 GB
    Page File Space 5.09 GB
    Sound
    Name SigmaTel High Definition Audio CODEC
    Manufacturer SigmaTel
    Status OK
    PNP Device ID HDAUDIO\FUNC_01
    Please find all details relating to chipset and sound:
    Any help is appreciated:
    SMBIOS Version 2.4
    Sound
    Status OK
    Yes I have - the problem is with SDK and voice training - the mic keeps on switching off
    Problem solved!! I downloaded IDT Autio Control Panel fromhttp://www.userdrivers.com/Motherboard/I...
    I now have control of everything including SDK taining and Input Monitor (ie hearing my own voice in my headset)
    Thanks again
    Thanks for pointing me in the right direction - downloaded new drivers
    Sorry, I don't understand your last comment. I had four people helping me and am thankful my problem was resolved. If there is a way I can give you positive feedback or a vote please let me know.
    Thanks again
  • 864 Answers
Well let me just start off with the basics here then from there we can go about helping you fix your problem. When it changes the microphone input, what input does it automatically select on the recording panel? Cause it has a default input it selects when you goto train. So say for instance if you have your microphone plugged into line input and in the recording control panel in windows it switches to microphone. Then you would need to plug it in that jack. Or vice versa. This happens to me all the time when i use torque game engine and use the voice to code console. Also are you trying to get it to playback live where you can hear through the speakers what is said through the mic. Or are you just trying to train the speech engine period. Cause i really need to know what input is being changed when you hit record and what its being changed to.
If you can help me by answering this questions we can go from there and i will be glad to assist you further. Thanks, Midwest-tek
Posted on Sep 08, 2010
  • 1 more comment
  • Nathan Ayers
    Nathan Ayers Sep 09, 2010
    when microphone is selected are you able to figure out which input that may be? cause i think microphone should be the rear green input.
  • Nathan Ayers
    Now is it a custom computer or is it a prebuilt pc such as a dell or a hp. An is the driver you have installed is that a driver straight from sigmatel or is it the driver that is issued by the computer manufacturer. Cause seems alot of people have this problem with sigmatels and they fix it by using the manufacturer sigmatel driver over the company driver. But it its a custom built pc with say a biostar or asus mobo that shouldnt be the case. Now my question is for you when you train the speech engine if you have the device window open can you select back to the microphone input that works. Like when it changes it to microphone select it to the rear microphone or whatever it is listed as. Or does the microphone even though the proper input is selected just stop being recognized?
  • Nathan Ayers
    Nathan Ayers Sep 10, 2010
    So it was the drivers and i told you it was most likely the drivers and you passed on my solution? i guess i dont understand why that is.
    Genius:
  • 1,400 Answers
Hello
Have you gone to contorl panel,sound settings,and done the voice recognition?
This will allow you to raise and lower the pickup of your voice and set the mic up for all applications.
Posted on Sep 10, 2010
    Master:
  • 497 Answers
Hello, I am going to help you the best that I can but at this time I do not know exactly which Machine you are on, or the Motherboard ID # if nothing else..
The best advice I can offer You is to go to the MANUFACTURER'S SUPPORT WEBSITE and download any/all UPDATES for the System/Board, which will include the Sound Device Drivers as well.. ok?
Posted on Sep 09, 2010
  • 4,889 Answers
Check to see what is your default recording device. Make sure that the MIDI device is selected. This can be done through control panel->Sounds->Properties. If you cannot find it there then please tell me what your OS is so that I can give you instructions specific to your OS.
Sai.
  • eagle338
    eagle338 Sep 10, 2010
    You are using the default driver provided by Microsoft. You need to install the latest audio driver made by intel to solve this problem. Can I have the model no of your chipset?
Why would I not be able to listen to music. starting 1 jan. i get the Pandora page but the artist does not and music
Minimum Specifications to Run Pandora
Most modern computers will play Pandora just fine, without any modification.
Minimum browser requirements:
Internet Explorer 7
Safari 4
Firefox 4
Chrome 7
Minimum hardware requirements:
PC desktop: Intel Pentium 4 2.33 Ghz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM, or
AMD Athlon 64 2800 or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
PC laptop: Intel Atom 1.6 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac laptop: Intel Core Duo 1.5 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac desktop: PowerPC G5 1.8 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Minimum internet requirements:
Consistent bandwidth of at least 150 kbps
If you upgraded to Pandora One and want to use High Quality audio, we recommend having at least 300 kbps of bandwidth.
If you're not sure of the speed of your internet connection, you can test your connection speed at any of these sites:
http://www.speedtest.net
http://www.dslreports.com/stest
Cookies Turned Off
Jan 02, 2015 | pandora.com Computers & Internet
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
I dont know where the model number on my computer is
I have to assume the sound is derived from the mother board. We'll need the Manufacturer of the motherboard (not the chips) i.e. Intel, Assus etc. and the model # which should be printed very close to the manufacturers name.
Mar 26, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Core (TM) 2 duo processor E7300, socket LGA 775, freq. 2.66 GHz, FSB 1066 MHz, L2 Cache 3MB, PCG 06, core 45nm what asus motherboard should i buy
buy any motherboard BUT asus.
asus tech support is rubbish.
i run my system on an ASROCK motherboard.
excellent boards, 2500mhz bus, can handle any cpu, most have 4 ram slots.
Feb 24, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
My Computer,Mouse & Key Board suddenly hang ho jata hai
what is the company of your motherboard?????? this is important to know...then I am gonna help u.....
Feb 22, 2009 | Computers & Internet
Playing CRISIS..
heres more info on the game
http://en.wikipedia.org/wiki/Crysis
Operating System - Windows XP or Windows Vista
CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
Recommended - 2 GB RAM
Hard Drive Space - 12 GB of free space
Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
Sound Hardware DirectX 9.0c compliant card
Jun 16, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Unable to install updates
First, do you know how to access the Event Viewer? Control Panel's "Administrative Tools" If so, are there any errors listed under WindowsUpdateClient? Anything under Bits-Client?
Also, you did Activate your Operating System, correct? Some updates will not install if the system is not activated..
DG
Dec 25, 2007 | Computers & Internet
MicroPhone Not working
Download the latest audio driver from intel site. Install it, ur mic will start working.....
Folloe the link and select Sigmatel audio driver
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2374&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#DRV
Nov 19, 2007 | Intel DG965RY Motherboard
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
