Question about Bunn NHB Coffee Maker
My bunn coffee maker is leaking water out the back
  • 189 Answers
If you will call 800-352-2866 with the model and date and we can assist you will this problem.
Posted on Sep 13, 2010
Bunn nhb disassemble
Most likely is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
Apr 23, 2014 | Bunn NHB Coffee Maker
Water leaking from my Bunn ThermoFresh
if it is under warranty contact bunn directly , if not throw it away . they are not fixable
Feb 12, 2014 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
