Question about Kenmore 54622 / 54624 Side by Side Refrigerator
I have a side by side Kenmore fridge & freezer model 970-563122. A week ago I discovered the condenser fan was siezed up when I was tracking down a water leak for the ice maker. I was able to locate a fan motor that fit on good. This fan pulls the air across the condensing coils as apposed to pushing it in the other direction. Does this matter and is this okay? The fridge seem to work good for a few days making ice but now it is not cooling even though I adjusted the thermostate down cooler. I felt the condensing coils now and they are about room temperature unlike before when I discovered the fan was siezed, they along with the compressor was very hot to touch. Any ideas what could be my problem Thanks Mike
    President:
  • 1,218 Answers
Good day,
That's not a good thing to do. First, shut it down, and let it get to room temperature. The engineers designed it to be either a push or pull style. My suggestion, is to remove the motor and go to an appliance parts house and get a blade that will make it a pusher. In this case 2 wrongs make a right.
However, there is a chance you damaged the compressor. Only testing will tell.
As well, the fact the old one was out had already created an overheating problem with the compressor and just makes the situation worse.
If no luck, it is possible the relay clipped to the body of the compressor is fried, and replacing it may work.
Beyond that you'll need a trained tech to determine the extent of the damage.
Posted on Sep 08, 2010
Kenmore side by side refrigerator model 596.50009100 not cooling.
I would make sure they fan on the bottom that cools the condenser is turning easy way to test is. Put a fan in front of the fridge blowing under it if it starts cooling that is now working right
Nov 12, 2013 | Refrigerators
Model # (P) 55662 serial # (S) 10149733GT Freezer is at 41' and fridge is at 49' and both are climbing. they were at 38' & 48' respectively this morning. * hours ago we tried: ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Kenmore Side by Side Refrigerator
Condenser side & compressor getting very hot
There is a fan you should be able to hear in the freezer.(it may turn off when the door is opened so hold the door switch in) It's behind the rear cover inside the freezer. The only other fan is underneath the fridge at the back behind the cardboard cover where the compressor is.
Aug 22, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Elite Coldspot side by side Model # 106.57706701 Frdige warm, freezer is frozen up. Have removed back panel several times in ther freezer to defrost coils and several weeks later, same problem.
check the fan that transfers the cold air from the freezer to the fridge. thats where it comes from if you didn't know that. also check the the fan on the condenser at the bottom of the fridge. it should be blowing hot air off the condenser to facilitate the elimination of the heat from the condensing unit, just like your a/c does on the houe.
Jul 20, 2009 | Kenmore Refrigerators
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Kenmore 54622 / 54624 Side by Side Refrigerator Logo
163 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
