Question about Clarion Sirius DXZ-535 CD Player
The cd player will work when turned on but when i release the front to change the cd, it powers off. it will work and the radio will work but after clicking the release and letting it come out about 45 degrees it shuts off. the radio is 7 years old and is used in a very dusty environment, any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clarion Master
  • 2,226 Answers
The flexible cable that goes from the face to the main motherboard is probably bad and needs to be replaced. unless you are good at soldering i would suggest you have it done professionally.
Posted on Sep 08, 2010
2010 Kia Rio 5 .Radio works but CD player doesn't. It displays Code 5 error.Any idea on how to fix??
Cd Player Error - Kia Forum
www.kia-forums.com/2003-2010-sorento.../59783-cd-player-error.html
May 11, 2010 - 10 posts - ‎5 authors
... Kia Picanto Forum · Kia Rio Forum · Kia Sephia Forum · Kia Sorento ... Have tried a whole range of CDs (copies and originals) but doesn't like ... If the negative battery cable idea doesn't work, try to remove the .... Last edited by pulsar86; 05-13-2010 at 01:42 AM. ... 5 Attachment(s) Kia elan T8D engine vs. Change Rear/Front Speakers 2006 Kia Rio (for ...
Jun 28, 2011
Resetting the radio - Kia Forum
Jun 9, 2011
Kia picanto 2010 cd player removal and mp3 - Kia Forum
Dec 29, 2010
Replaced battery and cd player/radio quit playing ...
May 7, 2008
More results from www.kia-forums.com
Remove Power Supply Fuse For Twenty Seconds if CD ...
Dec 27, 2015 | Kia Cars & Trucks
CD player just stopped working
Hi,if there is power to work the radio then the cd player should work, there could be a fuse on the sercuit board inside the radio.
hope this was some help.
May 04, 2015 | 2004 Dodge Durango
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
Replaced Car battery, now stereo not working properly
Have you tried resetting the microprocessor?
Remove the detachable face. There is a small pinhole on the front of the radio about two inches from the left side near the bottom. Press this in lightly with a fine point pin or paper clip. Hold about 3 seconds, then release.
Replace the face and try it. Let me know.
Dec 16, 2013 | Sony Xplod CD Player w/MP3 Playback...
I have a Power Acoustik PTID-7000NR and the cd is stuck and will not come out. It plays fien and everything else works. But the CD will not come out. Any suggestions? Thanks!
you may have two cd`s inside take the radio out and take it apart. inside the radio there is a realese for the cd tray but you have to have power to the unit for it to work. eject the cd from the front then hit the release on the inside its a little tricky but you should be able to find it
Sep 20, 2011 | Power Acoustik PTID7000NR Car Video Player
2005 Chevy Malibu Maxx cd changer error
You will need to have the radio reset or checked out at the dealer.Ther could be a cd stuck in it.Or the radio/CD player may have be on when the battery power got to low.
Jan 10, 2010 | 2005 Chevrolet Malibu Maxx
CD stuck in tray for DXZ648RMP player
Figure out what fuse controls the CD player and pull the fuse out for a minute (or more), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio and other settings. This trick seems to have the greatest chance of success overall.
Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
Jan 23, 2008 | Clarion DXZ648RMP CD Player
Power Amp not working When A CD is playing
Hi Cassiel,
You have it wired wrong. The Power Antenna wire is for antenna only. When you go to something other than Radio, the antanna wire signal to turn retract the antennaor turn off your amp. you need to use the Blue wire coming out of your CD player. The intended function of the Blue is remote turn on when every the radio is turned on. This will keep you amp on as long as your Radio is turned on. Change the wires behind the radio from the Power antenna to Blue Remote wire.
Dec 04, 2007 | Sony XPLOD CDX-GT200 CD Player
Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 15, 2007 | Emerson Smartset Clock Radio
Clarion Sirius DXZ-535 CD Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
