Question about Pioneer DEH-345 CD Changer
Ich besitze in meinem Auto den Pioneer DEH 345R Cd-Player. Ausversehen habe ich etwas gedrückt, nun steht MANU. wahrscheinlich für manuell? Seitdem kann ich keine Songs weiterschalten, wenn ich auf die Taste " > " drücke spult es die Lieder anstatt den nächsten Song zu spielen.
KaeZoo
  • 156 Answers
SOURCE: Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Posted on Mar 07, 2007
lobsterman72
  • 91 Answers
SOURCE: PIONEER DEH 245
Most aftermarket radios follow the same color code. W G G P, White, Grey, Green, Purple. LF, RF, LR, RR. red is switched ignition, yellow is constant battery, black ground.
Posted on Sep 02, 2008
SOURCE: changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Posted on Mar 15, 2009
PitVipermd
  • 54 Answers
SOURCE: My Pioneer DEH-P835R Cd Player will play my cd but wont eject
Check in the front and you should see a small hole thats about the same diameter as a paper clip. Open up a paperclip to a straight 2 inches and poke it through the hole. It should release the door so you can get it open or at least seat the cd if thats whats making it not open.
Posted on Apr 26, 2009
  • 137 Answers
SOURCE: need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Posted on Apr 18, 2010
Bluetooth free download AP to computer
i want to download the soft wire of bueltooth of dell d630
Jun 06, 2011 | Computers & Internet
Habe leider 3 mal den falschen code eingegeben nun soll ich den puk code eingeben. leider weis ich es nicht mehr. was mache ich jetzt?
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
Jan 02, 2011 | Nokia E50 Cellular Phone
Bei unserer Canon sehen wir kein Bild mehr auf dem Monitor. Man hat auch kein Foto wenn man abdrückt.
Ich hoffe, dass Sie mit den folgenden, wie ich nicht Deutsch sprechen, und ich bin mit Google übersetzer. Ein stecken Auslöser ist ein weiterer häufiger Fehler-Modus für Digitalkameras. Die Symptome einer stecken oder "klebrige" Auslöser sind sehr ähnlich zu CCD-Bildsensor Scheitern. Die Kamera kann Bilder aufnehmen schwarz (für Verschlusszeit fest geschlossen), oder die Bilder können sehr hell und überbelichtet, besonders wenn im Freien getragen (für Verschlusszeit fest offen).
Um eine Verschlusszeit fest zu bestätigen, legen Sie die Kamera in einem anderen Modus als "Auto", und der Blitz ausgeschaltet (Sie wollen nicht blind sich für den nächsten Schritt).Zunächst blicken die Linse und ein Bild. Sie sollten ein kleines Flackern in der Mitte der Linse sehen, wie der Verschluss öffnet und schließt. Wenn keine Bewegung zu sehen ist, dann haben Sie wahrscheinlich ein Auslöser stecken. Wenn ja, lesen Sie bitte diesen Link für weitere Informationen und ein einfaches Update, das helfen kann.
Mar 19, 2010 | Canon PowerShot A620 Digital Camera
Hallo, habe probleme mit meinem notebook , mein cd
Hallo, Plese nackten wth mir, ich bin mit dieser auf Google übersetzt.
Sie ersetzen können Sie es selbst ganz easil und ein DVD-Brenner legte in seinen Platz.
Rufen Sie die HP suort Website und laden Sie die Bedienungsanleitung lesen, sollten sie ein Wartungshandbuch.
Wenn Sie den Laptop auf den Kopf stellen, kann es ein oder zwei Schrauben, wo die CD-ROM-Klammern werden könnte auf der Innenseite werden.
Dies erspart Ihnen mit ein paar Euro, und Sie werden etwas gelernt, was auf dem Weg zu haben.
Ich hoffe, das hilft, aber zurück zu mir, wenn Sie weitere Hilfe benötigen.
Regards - Anthony
Jan 31, 2010 | HP Pavilion dv9000z Notebook
Ich habe einen speedport W721V und weiss nicht wie ich µorrent zum laufen bekomme
Kommt darauf an was du meinst damit, daß es "nicht lauft". Am unteren Rand des Fensters von µtorrent sieht man in der Mitte der Statusanzeige einen farbigen Punkt. Wenn dieser ROT ist, hast du wahrscheinlich ein NAT-Problem (vorausgesetzt, du hast deinen Port in deiner Firewall freigegeben. Wenn noch nicht, dann solltest du es jetzt tun. Wähle einen Port im Bereich zwischen 49152 und 65535, der ist nämlich bestimmt frei).
Meistens kommen NAT-Probleme daher, weil der Router den Verkehr für unautorisierte Ports blockiert; das ist eine Sicherheitseinstellung, kann aber auch mit normalen Datenverkehr Probleme machen. Neuere Router haben oftmals die Unterstützung des UPnP Protokolls eingebaut. Schau dafür in deiner Routerdokumentation nach, wie du diese Funktion im Router aktivieren kannst. Danach setze in µtorrent unter: "Optionen" "Einstellungen" "Verbindung" "Aktiviere UPnP Port Mapping" einen Haken. Das farbige Symbol (NAT-Anzeige) sollte von gelb auf grün wechseln, sobald du erstmals eine eingehende Verbindung hast (natürlich wenn du einen torrent laufen hast!). Wenn es aber rot wird, oder du im Reiter "Protokoll" eine UPnP-Fehlermeldung erhältst, dann schalte UPnP ab und leite deinen Port manuell weiter. Sollte das nötig sein musst du den Empfangsport für µtorrent einstellen. Dafür unter "Optionen" "Einstellungen" "Verbindung": einmal auf den Knopf "Zufälliger Port" klicken, und notiere dir den vorgeschlagenen Port. Diesen Port musst du jetzt in deinem Router weiterleiten (forwarden). Du kannst aber auch einen Port deiner Wahl verwenden. Jetzt den Haken bei "Bei jedem Start von µtorrent einen zufälligen Port wählen" rausnehmen. Damit bleibt der Port immer gleich. Wie gesagt, idealerweise steht bei deinem Port z.B. '34250-34377 Unassigned' (wenn du z.B. den Port 34343 gewählt hast). Das sollte es sein, wenn du noch Hilfe brauchst lass es mir wissen.
Wenn diese Lösung geholfen hatt, bitte klicke auf RATE :)
Jan 28, 2009 | Computers & Internet
Wackel - Problem
Mein Deutsch ist vielicht nicht mehr perfekt aber hoffentlich noch verstaendlich.
Es klinkt sehr nach denn baldigen kaputgehen von einen condensator im Netzteil. Sie werden benutzt den rest von Netz verwandten 'ripple' (storungen? - habe vergessen wie es auf Deutsch heisst) zu entfernen.  Sie sind zylindrisch und etwa 1 bis 6 cm gross und fast immer 90 grad zu den schaltplatine montiert.  Um defekten zu finden, man muss aber ein kapazitaetbrucke haben denn sie tun manchmal schlecht werden ohne aesserun was zu zeigen. Wenn was zu sehen ist, ihre alu deckeln koennen aufplatzen oder man sieht krystallen am schaltplatine wo sie sitzen.
Hoffentlich hilft es Ihnen etwas -
Greusse aus West Virginia - USA
Oct 29, 2008 | BenQ FP91G+ 19" LCD Monitor
Fritz!BOX fon WLAN 7170
DHCP und FritzBox gibt öfters Probleme.
Ich würde eher meine Drucker auf DHCP umstellen als den Rest der PCs und die Fritzbox.
Bei HP - Druckern kann man das via InternetExplorer ändern.
DHCP vergibt zwar die IP´s automatisch, aber nicht dauernd neu.
Erst wenn die maximale Anzahl an Geräten erreicht ist oder ein komplettes Reset gemacht wird.
In meinem Netzwerk laufen 5 Rechner und 3 Drucker, verbunden über einen SMC - Switch, alles über DHCP. Geht problemlos.
übrigens: das ist ein englischsprachiges Forum, da kann eine Frage auf Deutsch länger bis zur Beantwortung brauchen :)
Aug 18, 2008 | AVM Computers & Internet
Car Audio & Video Logo
71 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
