Question about Refrigerators
How to adjust the hopper temperature on a Taylor model 490?
I have a 754 Taylor soft serve machine and the mix freezes up on one side in the bin
I am assuming that it is the left side that is freezing up? Is there a large disparity in temperature from the left side to the right? Your machine monitors the temperature on the right side hopper and that will determine the temp of both sides. If there is a large temperature difference between the two sides then it may be that you are low on refrigerant. You may have enough refrigerant to cool the left side but not the right side and since the machine only monitors the right side, it wont shut off the mix refrigeration system which could cause the left side to freeze up.
Dec 29, 2017 | Taylor Ice Cream Makers
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
How to recognize why 339 raylor is not giving good product viscosity
If the machine runs and runs and can't satisfy your viscosity setting there is a refrigeration problem. The longer the machine runs the more the product breaks down, so you're problems get worse as the day goes on. It's not uncommon for these machines to lose refrigerant. I would guess that is the issue here.
You will need a refrigeration repair person to put gauges on the machine.
Here is some information I put together about the logic board adjustments on your machine. I think you might find this helpful.
Taylor Softech Control Boards
May 28, 2017 | Taylor Ice Cream Makers
Taylor 490 ice cream machine is shutting off
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Ice Cream Machine Support
May 02, 2014 | Taylor Ice Cream, Shake Machine 490-33
I took apart a Taylor 430-12 Frozen Margarita machine and need help on trying to reassemble it...
Taylor 430, craziest issue. Liquid is not flowing in hopper all the way. It stops and starts bubbling at the top. Nothing is blocked, reassembled several times with/without face plate. The water will only go halfway in the hopper. No type of blockage. can someone offer any ideas, suggestions. Im lost
Oct 09, 2010 | Taylor Ice Cream Makers
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
