Question about Sony KDL32L5000 32 in. LCD HDTV
My remote wont work with my sony bravia, and its doesn't change channels manually either.
YOU NEED TO REPLACE THE "H2" BOARD PART # 1-857-331-21
Posted on Jan 14, 2011
5 Suggested Answers
PABLOCSA
  • 1124 Answers
SOURCE: Remote Codes for new Sony Bravia
Sony has unique code for all equipments, those are 0000, and 0111, if doesn't work with your tv the problem it is on the remote control.
Posted on Nov 17, 2008
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
  • 5163 Answers
SOURCE: Can not change the channels on my Sony Bravia
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Posted on Sep 11, 2010
you should press 10000, which is the code
Posted on Jan 15, 2011
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
REMOTE WILL N0T CHANGE CHANNEL? HOW TO FIX?
Does remote change volume level or can open Menu in TV?
If yes, then its specifically channels buttons that do not work in remote and new remote would work.
Sep 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Re: Sony Bravia remote problems
sounds like you need to "autoprogram" your channels. In the customer menu search for "settings" (looks like a toolbox) select that, arrow down to "channels" select that, you'll see option for "autoprogram" select that. Any channel it sees it will lock in and you shouldn't have to press numbers anymore.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 27, 2009 | Televison & Video
Mar 06, 2009 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Jan 19, 2009 | Yamaha YSP-1 System
Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony KDL32L5000 32 in. LCD HDTV Logo
1,032 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
