Question about Canon XL1S Mini DV Digital Camcorder
Problem: xl1 Camcorder will not power up with the battery or the AC power or the power switch shut off.
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 08, 2010
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Posted on Oct 05, 2008
SOURCE: Connect Hitachi DZ-HS300A camcorder to AC power
it under the battery pack
Posted on Apr 04, 2009
SONY DCR200 CAMCORDER turn off when I Opend th LCD but it's working when attached with AC power Cable
More than likely the camera has an internal problem in the power supply section. There is an electronic switching circuit that switches between the battery input and the DC input coming from the AC adapter. Your camera requires professional servicing. One such place is AVRepair.com Home Services Consumer Camcorder Sony
Nov 25, 2014 | Sony Video Cameras
Error code
I believe this means that there is condensation in the tape mechanism.
Apr 06, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Auto power off
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
Dec 02, 2007 | Canon Optura Xi Mini DV Digital Camcorder
Screen goes black shortly after turning on
I'm sorry that the screen goes black shortly after turning on the camcorder. I suggest that you perform a manual power reset and check the operation. Follow the steps to perform a manual power reset:
  1. Turn off the camcorder.
  2. Disconnect AC power adapter.
  3. Remove the battery pack.
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
Jan 04, 2011 | Sony Handycam DCR-SR42 Camcorder
How do u reset jvc camcorder
Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the A position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
Nov 30, 2010 | JVC GR-SXM240U Camcorder
Keeps flashing c31-42 and shuts down
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
If you still get the error message you need to contact sony service center to get it repaired .
Hope it helps.
Jan 23, 2010 | Sony Handycam DCR-TR7000 Digital Camcorder
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
We are in the middle of a production (Live, right now) and one of our XL1's is shutting down whenever we hit the record button.
It may be timing out. Is the camera in standby mode? If yes, put it in record and lock.
I have an XL1 and a GL1 that sometimes shuts down. Is there a tape in the camera? It will time out sometimes if there is no tape rolling. Even if I am capturing directly to a computer, I always roll a tape, just to keep the camera from timing out.
What does your battery guage read in the viewfinder? A low battery will shut you down without warning. Try running from the power adapter if you have one.
Dec 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
223 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
