Question about Husqvarna Designer I
Needle clamp screw broke off and the end part of the screw is still lodged inside the needle bar. How can I get it out? Would appreciate any help!!
  • 201 Answers
Wow! That's sure a tricky situation! Just had a look at my needle clamp screw set-up through a magnifying glass. It seems to me that there is a very small Allen screw just above the needle clamp screw place. Could you use a small Allen key and undo this, hopefully releasing the whole needle clamp assembly. The cheap kits sold in chain stores for repairing glasses may well contain a tiny Allen key. Your next challenge will be to locate a new needle clamp assembly, but a Husqvarna dealer should be able to help you out there. There is an excellent online place for buying spares but I am very sorry I can't remember its name. Try Google? You could try taking it to a hardware store and seeing if someone there can help you with a suggestion on how to remove the screw shank.
Posted on Sep 09, 2010
Husqvarna 1100 the needle does not go in the shaft but next to it. What happen and how can it be fixed. Adriana
Posted on Mar 08, 2011
Needle clamp screw broke off and the end part of the screw is still lodged inside the needle bar on a Toyota sewing machine , series EC1 , Model 2440
Posted on Mar 30, 2011
I have a singer futura XL580 and the thread guide either flew off or broke off. I thought I bought the right replacement part no. 086046 but can not seem to figure it out
That is because the thread guide is underneath the needle clamp, and BOTH must be removed and replaced together as a unit. In addition, the wire is held by a tiny screw in the back of the shaft. That screw also serves as the stop for the end of the needle. Take a look at the shaft right above the needle, and you'll see what looks like a grey bar--that is the screw. It's difficult to access on the back, but must be loosened first -- JUST ONE OR TWO TURNS -- to remove the wire. Then, take off the needle clamp and wire as one unit.
Insert the replacement guide inside and at the back of the needle clamp, with the hook part sticking out of the clamp. You'll see that there's an indentation in the clamp to hold it. Insert the guide and clamp as one unit, then hook the wire around the screw and tighten.
FYI - If you accidentally remove the screw (which only turns about three or four times) and drop it as I did, you don't really need it to hold the wire guide, BUT you still need a needle stop. I just inserted a toothpick when I changed needles until I could get a replacement.
The above sounds relatively easy, but you'll probably have to do some manipulating, especially the first time, and if you're like me, possibly some cussing -- but it WILL fit.
Dec 31, 2016 | Singer Sewing Machines
How do i remove the needle clamp assembly from bernina 1090?
Remove the needle bar clamp screw. From the back side of the needle clamp holder, remove the small needle stop screw. The clamp can then be slid down off the end of the needle bar. You may have to swivel the clamp back and forth as you slide it down in order to remove it. Some clamps are fairly tight.
Jul 08, 2014 | Bernina 1008
Thread keeps knooting up
is the bobbin threaded correctly ?
is the bobbin warped?
try rethreading the machine top & bobbin
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check to make sure every thread guide is used
Jun 11, 2012 | Brother Sewing Machines
Janome 9000 bobbin thread ends up on top of fabric
change the needle--
rethread the top thread--top & bobbin
check the bobbin to make sure the bobbin is not damaged
reinsert the bobbin in the case correctly
Jun 03, 2012 | Janome Memory Craft 9000 Computerized...
How do I remove the needle clamp from the needle bar on a Singer Futura Quartet sewing machine?
try undoing the lock screw fully and gently move the clamp in the opposite direction the the lock screw, it should drop off.
May 30, 2012 | Singer Sewing Machines
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
My needle broke. How do I fix it?
hi! there, first you have to raise needle bar to its highest position by turning the handwheel toward you.hold the broken needle itmay drop after loosen broken needle.,loosen the needle clamp screw using by a srcewdriver pull out broken needle.take new needle holding the needle with the flat side away from you.slip the needle into the needle bar groove.make certain it is up as far as it can go tigthen the needle clamp screw with a screwdriver,aas shown1b71a34.jpgregards
Mar 28, 2009 | Euro-Pro Shark 60 - 384
Needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Jan 30, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
586 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
