Question about Sharp AR-M207 All-In-One Laser Printer
LA COPIADORA SHARP AR M207 TIENE UN CODIGO DE ERROR E7-11 POR FAPLIS ME PODRIA AYUDAR CRACIAS SOY SOL
SOURCE: Oxd0620230 reset power
my printer is a hp officejet j5750 all in one, the probem is that I can't scan in it, but I can print, send fax, an make copy in it, so the only problem is the scaner, plese help me
thanks.
Posted on Mar 04, 2009
SOURCE: Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Posted on Jan 07, 2010
ermiaby
  • 54 Answers
SOURCE: mi copiadora sharp AR5125 tiene codigo U6
code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
Posted on Jan 14, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
SOURCE: que significa el codigo f2-02 de una copiadora
me marca codigo f2-02 copiadora sharp AR M455N
ke puedo hacer sera que es le chip o el cartucho.
Posted on Oct 20, 2010
En la fotocopia dora me aparece llame al servicio tecnico COD.U2-40 y no me saca copias copiadora es SHARP AR-M237 AYUDENME
Hola buenas tardes, me podrian ayudar tengo una copiadora sharp ar m237 y me esta marcando el codigo U2-40 y no se que hacer alguien pude hacesorarme
Jul 20, 2011 | Sharp AR-M237 Copier
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com
Feb 28, 2011 | DISH Network IR Remote Control
Enciende y aparece el logo de la bateria y luego se apaga , y por mas que lo haga cargas mas horas sigue igual . Por favor no se sin ayudar
Si cuando te aparece el logo de la bateria, esta tiene poca carga a pesar de haberla cargado durante horas, entonces podria ser:
1) Un da?o en el cargador (en este caso igual no funcionaria aunque tuvieras la laptop conectada directamente al tomacorriente). 2) Un da?o de la bateria (la bateria no esta tomando la carga). 3) Un da?o en la fuente de poder.
Tambien te recomiendo revisar que los contactos esten limpios: 1) Donde la bateria tiene partes metalicas que hacen contacto con otras partes metalicas de la PC. 2) Donde hacen contacto las partes metalicas del cargador con las partes metalicas de la laptop.
Asi podras saber si tienes que cambiar el cargador, la bateria o si tienes que llevar la PC a un taller a que le revisen la fuente.
Oct 19, 2010 | Computers & Internet
Como programo un dvd player sonny
Hola mi nombre es Kimberly Escobar soy representante de Dish Network servicio al cliente. Estoy respondiendo a su pregunta para ayudarle y proveerle la informacion necesaria para programar el control con su DVD. Hay ciertos codigos que tenemos que integrar al control para que pueda funcionar con el DVD por ejemplo unos de los codigos serian 731, 501, 617, 500, 117, y 671. el procedimiento es el siguiente: en la parte de arriva de su control va a oprimir el boton de AUX hasta que los demas botonos se iluminen en rojo una vez esto suceda usted va a ingresar un codigo (antes de el codigo siempre va un numero 1 primero por ejemplo si usa el codigo 731 enrealidad seria 1731) seguido por el signo de numero (#) por ejemplo 1731#. el boton AUX deberia iluminarce en rojo 3 veces, despues de esto puede intentar usar el control con su DVD. Desafortunadamente no le puedo prometer que funcione pero el definitivamente el procedimiento a intentar. Si tiene preguntas o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le ayude.
Sep 30, 2010 | DISH Network IR Remote Control
Me gustaria tener el codigo de mi tv KLH digital no lo encuentro los codigos mi tv y el dvd son juntos los dos y no se como programarlo muchas gracias
Esta Television nesista su propio remote y esta es un problema si usted no la tiene pero si puedo compra una y asi es la unica solucion por esta problema usted cuento la sitio www.remotes.com si puede ayudar en muchos aspectos. Si puede comprar un remote que lo functiona por esta tele es que esta fabrica KLH es moy rado y no tiene la supporte usted esta buscando esto no es problema mia es un problema de frabricante porgue ellos nada mas vende y cerra sus puetos a cliente. Espero que esta informacion ayuda usted pardon mi forma de escribe yo no sabe mucho espano por favor dajar sus votos y propio commentarios positivos Gracias por su visita a fixya.com, Saludos
Nov 18, 2009 | KLH 13" TV
Conoces el codigo de control que le corresponde a un dvd LUFs?hn, te lo agradeceria enormemente, ya que se me descompuso y tengo un control de una tele que podria usar, pues tiene la opcion de controlar...
buenos dias, necesito el manuel del control jenser 323, para codificarlo con un dvd, por favor si alguien puede ayuidarme, lo agradeceria mucho mi correo es asdruba_yo@hotmail.com, mandenlo aqui por favor, muchas gracias, que tengan buen día.
Mar 09, 2009 | Jensen 143307 Remote Control
Zyxel 964
gracias por comunicarte conmigo te cuento me regalaron un zyxel prestige 900 cable router 964 se q fuciona pero no lo puedo instalar no se porq mi computadora no lo lee es una hp pavilion dv9410us notebook pc no tengo el software del modem y no se como conseguirlo me podrias ayudar?? muchas gracias!!! andrea
Oct 18, 2008 | Zyxel Prestige 964S Router (02009900001)
Sharp AR-M207 All-In-One Laser Printer Logo
407 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
