Question about Craftsman 10" Table Saw
How do i change a 10 inch blade on my table saw
  • 490 Answers
Howdy, Start by unplugging the machine (mandatory safety nag, sorry) then jam a nice piece of 2 x 4 in the teeth of the blade and remove the red blade surround plate. Use the blade wrench or crescent to loosten the side nut by turning towards the point of the teeth on blade. Remember the order of any washers as you remove, and replace in reverse after adding new blade ,being careful to orient the blades in the same direction as the original. Make sure all is snugly tightened and replace all guards to finish. Ta da!
I hope this gets you quickly back to making sawdust:)
Regards, Farmerbear at FixYa.com
Posted on Sep 09, 2010
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
Oct 25, 2011 | Craftsman 10" Table Saw
I lost the blade change wrench for fire storm 10 inch table saw,cant find a tool that will fit
probabbly have to order off line. or sears hardware may carry them. or a speciality woodworker store.
Jul 08, 2011 | Black & Decker 10-in Firestorm Table Saw...
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
How do I change the blade?
Unplug the saw. Remove the plate that the blade goes through this will allow access to the nut. Raise the blade several inches above table deck. Place a block of wood under the teeth to bind the blade so it won't rotate you should be standing on the infeed side of the blade. With a wrench loosen the nut (Towards You) Reverse to reinstall. It is also a good idea to wear leather gloves in case you slip the blades can still do damage even when dull. Hope this helps please rate if this was helpful in any way. Good Luck and have a great weekend.
Mar 31, 2010 | Jet 10 In. Proshop Contractor Style...
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Craftsman 10" Table Saw Logo
103 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
