Question about Electrical Supplies
The gas tank has rusted on the inside and need to purchase a new one but can;t find one. It is a valsi 7500 generator with a tecumseh engine.
  • 2,841 Answers
Call 1-866-260-4843 http://www.valsi.com.mx/Default.aspx?lenap=1&olac=2&sedo=3 Hover over Support and then click Service Center or Distributors. You should be able to find a distributor or service center near you. One other option is to just install a fuel tank from another brand that will fit within the area that you have for the fuel tank. You can modify the mounts and secure any fuel tank that fits.
Posted on Sep 08, 2010
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Gas tank leaks is rusted inside and out am looking for a replacement tank
find a honda dealer and pray its not expensive... Or find a small engine shop and see if they have some junk generators laying around and buy the best tank they have and make it work...
Dec 27, 2013 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
I have a valsi 7500 watt 13 hp with tecumseh enduro xl/c engine-its extremely loud and wouldn't stay cranked. My ex - an ''idiot'' worked on it without my knowledge - we now have lines that we don't know...
Valsi 7500 watts/13hp tecumsa engine. Was running fine and then started surging like it was going to die and then it ran out of gas. Put fuel in it and now it wont start. Gets fire and has plenty of gas. Problem???
Jun 23, 2010 | Electrical Supplies
Need new gas tank
A couple things you can do here...
1) Drain the tank, blow it dry using compressed air, and get all the rust out that you can. Use an acid wash / rinse to help remove the rest of the rust. Coat the tank inside with a tank sealer like that from kbs-coatings or caswell.
2) Have a metal shop make you a new tank that will approximate the old one.
3) Install a fuel filter that will catch the rust particles (left over after blowing it out) and be done with it
4) Use an external fuel tank (marine comes to mind) instead of onboard fuel tank.
May 11, 2010 | Coleman Powermate Premium Plus 6250W...
Have a VALSI 5500 watt generator that works fine but the tank has rusted out and I cant find where to purchase a new one. Can you help me find where to purchase this tank
We had problums with this one also. If you absolutely cant find a tank repair it.
A motorcycle shop in your area has no doubt had plenty failed tanks to repair. and then have it plastic coated on the inside.
The problems stem from the use of fuel with ethanol it attracts watter and dosed not work well in a gen set that spends lots of time setting.
Begin using fuel with a fuel stabiliser and keep it full, Air also has water in it.
r/
David
Jan 05, 2010 | Watts Onan Portable Generator - 4000 ,...
VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
Valsi Generator 7500W no output voltage
Good Luck with that...but if engine runs and there is no output voltage, that generally means that the stator needs to serviced or replaced (likely as pricey as a new genny).
Mar 10, 2009 | Electrical Supplies
Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Sep 18, 2008 | Electrical Supplies
Electrical Supplies Logo
101 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
