Question about Canon imageCLASS D880 All-In-One Laser Printer
I have got a CANON ImageClass MF3240, and I can not get it Started, it was working perfectly fine yesterday, but now it won't even start or light a led from the front panel. I've checked the power cord with a multimeter and also the power inlet of the printer, as a Result, I had everything powered right. It seems like the power won't go to the START button so it can be turned on. How can I get this fixed?
  • panchoga1209 Sep 08, 2010
    I have done these solutions for getting the printer to start, but non of them, at least the 1-4 didn't work. Do you recommend me to change the power supply? Do you have any idea how much would cost that?
    Thanks very much!
  • panchoga1209 Sep 09, 2010
    Hi again,
    Do you think the problem is caused by the power supply board?, I plugged it up and check any voltages in the boards, but non of them had power besides the power supply board. And if so, where can I get the PCB?
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link bellow to have a general idea when a printer wont turn on:-
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpd05351
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 08, 2010
Canon imageCLASS MF3240 All-In-One Laser Printer Downloade
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
May 12, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Canon MF3240 firmware update failure
YOU THEN NEED TO REINSTALL IT BECAUSE YOU CANT ROLL BACK THE FIRMWARE
Mar 29, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
I bought a new Canon image clas MF3240. I installed the software but it does not print. How do I print?
Make sure the software is installed correctly. Add your new printer on your hardware in computer to make them paired perfectly.
Jan 05, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Refilled cartrige on MF3240. Says out of toner. How do I reset it?
Hi there
This is because of the refill you can try going to your menu and then reseting it, the old chip still see that it was emty.
All the best Pineworks
Apr 28, 2010 | Canon MF3240 imageCLASS Laser...
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Canon MF3240 error code E000
change ink, if problem continues change scanner
May 17, 2009 | Canon MF3240 imageCLASS Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
69 people viewed this question
old marine
old marine
