Question about Dacor Ovens
When I cleaned the Convection oven yesterday, I set it for 3 hors and 25 minutes. When it was finished and apparently cooling down the F2 message came on the left side if the clock. It had never happened previously. I canceled the cleaning and it wentaway. What did I do wrong? Or, why did this happen becauseI never saw it previously.
  • 944 Answers
F2 message shows appears because the heating sensor as sensed high temperature.When the ERC senses high temperature then You will get F2 error.Some times alarm beeb will go on.The ERC will alarm and show F2 until the cancel or another function is selected.This is to intimate the oven temperature is beyond level so please let it cool down.
Don't worry this is like error code and for your information it showed up.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Sep 17, 2009 | Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Dont know how to use
Many ranges now have automatic conversion when you use convection feature instead of standard bake, but as a general rule, if your standard baking time in the recipe is over 30 minutes, you can lower the convection setting by 25 degrees F and reduce the time by 25% to get the same results as standard baking settings. Please don't rate this if you don't feel it is a Fix-Ya for you, as other ratings lower my score. Thanks.
Jan 20, 2009 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
