Question about Hoover Dishwashers
HI TIMES TODAY I HAVE PUT ON MY HOOVER DISHWASHER , IT GOES THROUGH THE CYCLE RIGHT UP TILL THE DRYING THEN THE FLASHING LIGHT THAT SHOWS ITS WORKING JUST STOPS AND THEN NOTHING, PLEASE HELP
  • Hoover Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 10, 2010
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
Hoover DT 999 shows E3. No hot water & no drying. Do I need a heater element or could it be some other problem?
A bad heating element causes many problems in dishwashers...
How to Replace the Dishwasher Heating Element
heatman101
Jan 19, 2011 | Hoover 24 in. DT999 Free-Standing...
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Poor washing and drying
I have the same problem. Could you please let me know if you find a solution. I will do the same.
Jan 09, 2010 | Ariston Technologies LI640S Dishwasher
Drying light keeps flashing
You said,
Drying light keeps flashing and beeping. dishwasher will not start. turned off circuit breaker and turned back on same thing happened again.
It seems you have an electrical fault in the dishwasher and it will not permit the start of the motor,
as a safety guard.
You must have the electrical system checked for shorts .
Otherwise the motor is dead!
huuum,happy to assist you!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Sep 18, 2008 | GE 24 in. GLD5560LSS Stainless Steel...
Dishwashers Logo
204 people viewed this question
Top Hoover Dishwashers Experts
Gil Shultz
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
