Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
I just need to know what belt I need to purchase for the bissel liftoff revolution vacuum
  • 52 Answers
Here is the belt if it is a bag-less model
http://www.totalvac.com/B-3200ES.html
Posted on Sep 09, 2010
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
Apr 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My liftoff revolution smell like it is burning after I use it
That means that the belt is worn and is starting to slip. You need to replace the belt. Here is the belt you need and a manual you can view with instructions:
Bissell Lift-Off Revolution Belt and Manual
Mar 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Vaccum works but will not **** up anything. i have cleaned hoses and filters
have you checked to see if the belt is attached to the brush roller? That's a common problem. Check your belts
Feb 10, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
It won't pick up. I cleaned all of the filters. what next?
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Nov 17, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
http://www.vacbelts.com/bissell-lift-off-revolution-pet-vacuum-belt-.htm
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Bissell liftoff brush wont turn
Check the connections on the bottom of the lift off part, and the matching connector on the bottom section. If bad, take it to a warranty repair shop for Bissell. Other wise it could be the brush motor that is bad, or the switch is bad.
May 15, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
