Question about Acer Aspire One Netbook 8.9" Notebook
The writing and logo's on the desktop are too big,it seems like the resolution is too high . i have done a full restore and the problem still persists
    Problem Solver:
  • 13 Answers
It is likely that the correct video driver did not get installed after you performed the 'full restore'. You will need to to go to Acer's website and enter your model number in the support area to download the correct video driver. Install the driver and reboot your computer.
Posted on Sep 08, 2010
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Screen size too large
Click the Apple logo button in the top left corner of your desktop.
Then click System Preferences.
Click Displays under Hardware.
Play with the screen resolutions there until you get what you like.
Jan 26, 2014 | Apple Mac mini G4 Desktop
Screen resolution is too big. Unable to correct.
The resolution is set too high, or the icons are too large? If the resolution is too high, the items appear smaller. If the resolution is too low, it gives a "zoomed in" appearance, and everything is much larger.
Has this issue been present since day one, or did it just begin?
What operating system do you have?
Do you have a dedicated (PCI, AGP, PCIe) video card, or are you using the one on your motherboard?
It sounds like you need to update or re-install the drivers for your videocard. They may have become corrupted, and are disallowing your resolution to be set to your desired spec. Many videocards will reset themselves to 800x600 if there is an error with the drivers, making everything seem much larger on the screen.
Oct 06, 2012 | E-Machines eMachines Desktop PC
The screen has gone small and i need to get it back to big can you help
If you are using XPRight click on your desktop and goto: Properties>Settings>And drag the 'Screen Resolution' Bar all the way to 'Less' If you are using Vista/7 Right click on your desktop and goto: Screen Resolution> And drop the resolution bar a move it to 'High'
Mar 01, 2011 | Computers & Internet
Desktop screen saver was not full screensize, so i set to maximum setting 200% and now the whole thing is too big and desktop icons way too big to work with, how can I get into system to reset or...
It sounds like you changed your desktop background resolution settings and not the screensaver. Right-click on your desktop on any clear area that doesnt have an icon and if this is WinXP select properties, or if Vista select personalize. Select the settings tab and you should see a screen resolution adjustment slider that will allow you to change your screen rsolution which intur affects the size of all your icons etc. Select the size that suits you. 1080 X 786 is a good place to start. You're probably set to 800 X 600 right now.
Oct 31, 2010 | Microsoft Windows XP Professional
Fn and spacebar make icons really big
Hi, right click on the Desktop Screen; select from the "View Icon sizes in the window, "medium, small..." If the solution helped, rating it is appreciated, thanks
Mar 18, 2010 | Toshiba Sattelite A105-S2071 Notebook
The screen and everything on it is enlarged very big and even after changing the settings and doing a system restore it won't change
CHANGE RESOLUTION OF YOUR MONITOR. RIGHT CLICK ON EMPTY DESKTOP, SELECT property, SELECT display, AND resolution. INCREASE RESOLUTION TO 1600X1200 OR SIMILAR. PROBABLY IT IS SET NOW AT 800X600.
Oct 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
The software is too big for my screen, I cannot see any menu or tool bars so cannot use
Press "Windows logo" key from your keyboard to see task bar and menu.
Or
Press "Windows logo" key + D to see desktop, task bar and menu.
or
Change your screen resolution to bigger size but remember selecet resolution according to the monitor maximum resolution.
Nov 24, 2008 | Computers & Internet
Restore active desktop
As the icons have increased in size that means ur screen resolution has changed
Goto desktop
right click on desktop  >>  Properties  >>  settings tab
now u will find the Screen Resolution adjust it according to ur requirement and u will find ur icon size small again  ( if u increase the screen resolution)
For internet settings Create a New Connection Wizard
or u can check from Network Connection whether ur Local Area Network is Enable or not.
Thank You
Vinay Ramani
Oct 12, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
