Question about Hayward H Series Pool & Spa Heater Electronic Dual Ignition 150,000 Btu Natural Gas H150ed2
Hello- my customer is getting mulitple error messages on her H150ED2 pool heater, we just installed a new control panel and it fired up just fine 3 times before my tech left,. Then it sat for a few days because the customers husband was in the hospital. The error codes she is getting is SF, HS, S. She does not have a spa, but she's telling me one of errors pops up when she puts it to spa. That doesn't matter anyway, correct. Marisa
  • 331 Answers
Suggest you contact Hayward directly at https://www.haywardnet.com/forms/contactForm.cfm
Posted on Sep 10, 2010
How to relight piolet
The H Series electronic ignition does not have a pilot light. It has an electronic ignition that, if all conditions are met, will start the heating process
Aug 09, 2014 | Hayward H Series Pool & Spa Heater...
Manual reset switch
sounds like heater is getting too hot make sure if plummed with a bypass it is only open half way if no bypass make sure filters are clean if ok check manual bypass maybe spring is stuck open
Aug 06, 2014 | Hayward H Series Pool & Spa Heater...
Hayward spa pool heater pilot on, heat does not ignite burners
Don't really think the gas company would be checking your pool heater, they most likely just checked their gas connections. I would suspect a few things; control module, thermostat, gas valve, pressure switch. You say you get pilot light, and as long as it doesn't turn off and on, as if it is not being sensed, then I would suggest the control module is fine. If the pilot and main burner is controlled by the same valve, and your pilot light stays lit, then I would suggest the thermostat is fine. I take back the pressure switch since the pilot will ignite. I would check power to the gas valve solenoid and see if the control module is trying to open the gas valve. I would suspect low voltage, probably around 24v. If voltage is present and no gas, I would say you found the problem.
Apr 09, 2013 | Hayward H Series Pool & Spa Heater...
Display shows SF on model H150ED2
SF is the code for Temperature sensor input failure. check wiring that goes to temperature sensor for brakes or cuts, sensor is located on right lower side of heater where water lines go in. you have to remove the 6 screws to take the side panels off above and below the water lines. sensor is visible then.follow wires back to control board and make sure they are securely pluggin in to board and all broken wires fixed or replaced. If no broken wires or loose connections, Replace temperature sensor.
Aug 29, 2011 | Hayward H Series Pool & Spa Heater...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Mar 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater Electronic Dual Ignition 150,000 Btu Natural Gas H150ed2 Logo
261 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
