Question about Coleman Electrical Supplies
I'VE got a coleman powermate 5500, i've got no output from the plugs. i've tried the circuit breakers. is there a fuse somewhere?
    President:
  • Coleman Master
  • 1,388 Answers
There is no fuse. Most common problems are loose connector from panel to gen set, worn brushes, faulty rectifier board or needs to be spiked (more serious reasons but lets not go there). Brushes and panel easy to check, remove cover to gen. and look at brushes for good contact to com. rings. Remove rectifier board from mount and look at capacitor for leaks or swelling. Replace as needed. Parts are available at jackssmallengine. com There are many ways to spike gen. as seen when you google the subject, however I just use a one amp 12v battery charger (or any small dc power supply 1/2 amp to 1 amp) and very quickly/split second contact brush connector while engine is running. Mind polarity, you must know which brush is positive. Usually on coleman the brush closest to bearing is positive. Spiking works immediately, if no joy, more serious problems exist. Dont worry, you cant break anything doing this, remember it is already broken. Post again if you have other question. Good luck
Posted on Sep 08, 2010
PM0543000.01 no output
You cannot check the diodes problem while they are in circuit. It could be several factors, but if you have gone that far, remove diodes and check orientation before removal, test one at a time.
Jul 01, 2013 | Electrical Supplies
Powermate 5000 generator motor working .no elektricity
If the genset is working but there is no output then it is possible that the circuit breaker has TRIPPED due to short in the line. So remove the load to the genset and power the engine . Now switch on the mains switch and see if there is output. It there is no output then it is possible that there are problems in the ALTERNATOR. You will need to check if there is safety cut off/fuse that has failed or there is problems in the wiring.
Jul 05, 2011 | Coleman Powermate Powermate 5000W...
No output
  1. Check the breaker to be reset before applying load.
  2. Check field connections, fuses, AVR.
  3. With running Gen. Apply a 12 V battery for 1s to the field + and - respectively.
Jun 15, 2010 | Coleman Powermate Premium Plus 6250W...
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
Motor runs but doesn't deliver electricity
Make sure that the alternator is being turned by the engine--sometimes the mechanical coupling fails. Check for a tripped breaker/blown fuse. Beyond checking for bad brushes (if used), you will need a wiring diagram and an AC/DC voltmeter/ohmmeter to chase out any troubles in the alternator. Be aware of voltages up to 230 volts can be found inside even if there is no output.
Dec 03, 2009 | Coleman Powermate Powermate 5000W...
Does not generate electricity
check your fuses or circiut breakers...
Aug 06, 2009 | Coleman Powermate Powermate 5000W...
Running but putting out power
You need to remove the cover where the outlets are at and measure the voltage before the breaker. There are no fuses on the output side of the genset only breakers. If breaker is fine but still no output, try flashing the fields with a 12 volt battery. If voltage increases then your voltage regulator is bad.
Apr 15, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 reset problem
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman powermate mod# pm0477023
I guess Just Check to make sure all circuts are closed... that is robalbey the best a can do with the info you gave me... try consulting the troubleshooting section in the manual. Hope this helps
Sep 29, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Electrical Supplies Logo
627 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
