Question about Dell PowerEdge 2950 (becwfk1_6) Server
Unable to determine the boot device. Drives may not be initialized. Initialize using the BIOS utility, or check if the disk are connected properly. This is using server manager CD
2 Suggested Answers
  • 37 Answers
SOURCE: Unable to determine the boot device. Drivers may
You need to go into setup view you drive array sounds like you may have one bad drive or the raid array has dropped by moving drives around hope this is what is wrong then re initialize the drive array you need more help email me at mje.bend at live dot com
Initialize using the BIOS Utility .
Posted on Nov 21, 2009
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
Second drive unable to initialize
hello,
boot with one live cd windows or linux and recover what you need then change the cables from the first one to the second one.
Jan 14, 2014 | Seagate BARRACUDA Computers & Internet
I have a problem with my LG External HDD HXD5. It's installing on my system (windows) but I unable to access. The computer is asking m to initialize the disk and I wondering to lose all my data
HI,
in the past i have used GetDataBack program utility and worked fine. Before that you could also try HDD regenerator to check and fix any error on the disk.
Marco
Jun 24, 2012 | Computers & Internet
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
Installed a WD Caviar Green SATA internal hard drive in my Gateway PC. The bios doesn't show it, the device mangler doesn't show it. I disable the antivirus software & the UAC as suggested by the many...
New HDD Not Recognized by Computer
This occurs when the HDD is not “Initialized” by the disc management system in Windows. If you do not have software that came with HDD or the HDD is a secondary drive for backup and is not to be used as an initial boot device, then when you installed the drive it did not go through the necessary steps or Windows simply failed to do it’s job. In this case, connect the drive as you normally would, go to the control panel > Administrative Tools > Computer Management > Look in the left Pane, scroll down and click on Disk Management.
Your drives will be listed here, even if they are not initialized. Look below the top pane and find the disk that is listed without a drive letter. If you look at where the drive is named, it will also say “offline”. Right click in this area that says “offline” and click on “Initialize”. The system will ask a few questions, just click ok to what it asks, this will initialize the disk and you can then partition the new drive to how you want it set up.
Jan 18, 2010 | Computers & Internet
Unable to determine the boot device. Drivers may not be initialized. Initialize using the BIOS utility, or check if the disks are connected properly.
Nov 07, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
I took out my old hdd, and put a new one in with double the GBs.....but now when I turn on my PC, all I get is a blank screen? Won't let me load the OS....
First set your harddisk as master which has operating system.
And set slave as your new added hdd.
You can ser master and slave with jumper settings.
Read diagram on HDD.
Then check .
Also check in bios that your first boot device is your hdd which has os.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | Dell Dimension™ B110 PC Desktop
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
I was given a MAXTOR 500 GB SATA HDD which I installed into my desktop. Once powered up, the HDD had an audio (almost chime)tone. The desktop installed the drivers but would not display the HDD in MY...
Hard drives do not generate audio tones for error messages or POST codes. Any problems should be reported by the BIOS on boot. The disk may not be showing up under Windows Explorer for other reasons, so...
Open up Disk Management (right-click on My Computer for XP, Computer for Vista) and select Manage from the context menu then select Disk Management from the left-hand pane. In the middle pane, scroll down until you find a disk that is Not Initialized or Offline.
If it is marked as Not Initalized, right-click on it and select Initialize Disk. After the disk has been initialized, you need to create a parition by right-clicking on unallocated space of the disk and selecting New Partition from the context menu. Follow the wizard to create the partition. Once the partition is created, right-click on your new partition and select Format from the context menu and follow the wizard to format the newly allocated space. Once this is done, you will be able to utilize the disk.
If it is marked as Offline, right-click on the disk and select Reactivate Disk from the context menu. If the disk is partitioned and formatted already, you should be able to use the disk immediately, otherwise follow the instructions above for partitioning and formatting the drive.
Jun 04, 2009 | Maxtor MaXLine Pro 500 500GB 7200rpm...
Disk boot failure
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Dec 09, 2007 | Intel Server Board SE7505VB2 Motherboard
Dell PowerEdge 2950 (becwfk1_6) Server Logo
516 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
