Question about HP Color LaserJet 4550 Printer
I need to connect my HP 4450 printer to a usb port on my computer. The parallel port on the printer is c-size
  • HP Master
  • 629 Answers
You'll definitely need to use an adapter/cable to convert/connect USB to parallel or vice-versa. You can do a quick search on the internet or even check with your computer /printer store/dealer for it.
Posted on Sep 08, 2010
HP T45 Connectivity Problem
You may check the link below for manufacturers that sell this product that you need.
Link
Aug 04, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Is it possible to connect an old, still very efficient HP 5L Laserjet Printer which uses parellel port cable to a new computer via a USB cable? If yes, what do I need?
Yes it is. You just need a Parallel to USB adapter. Here is a link to an example of what you need.
Parallel to USB
I have done this several times with Parallel Receipt Printers. Works Great!!
Another option would be to add a Parallel Port to your new computer. Here is another link.
PCI Parallel Card
The 1st option is probably the cheapest and easiest.
Good luck and have a great day!
Feb 26, 2010 | Office Equipment & Supplies
Can the P2055d be connected with a parallel lead?
Most HP's if they have a port for parallel, it is a special plug on the back that looks more like a SCSI plug. If your printer has this plug you need the special cable, otherwise you will need an adapter to convert USB to parallel.
Dec 28, 2009 | HP LaserJet P2055d Printer
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
Dec 10, 2009 | Cars & Trucks
Connecting the HP Laserjet 9500 hdn
This unit is meant to be used on a Parallel connection or an JetDirect Network adapter, for use over the local network.
If you want to use the Parallel port, you would need a computer which has a Parallel port on it and a Parallel printer cable.
According to the specs, this unit came standard with a HP Jetdirect 620n Fast Ethernet .
You can conect it to your router. This way all the computers can use it via the network.
Here is the user guide:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl13223/bpl13223.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Office Equipment & Supplies
My printer doesn't have the usb to connect it to the computer - what do i need to do?
If the printer does not have the square USB connector (USB B end), then it will have parallel. Parallel is a wide connector that plugs in to a DB25 connector on the back of your computer. These parallel port printer cables can still be picked up at just about any office supply or computer store.
What if your computer does not have the DB25 parallel port but the printer does? Well there are USB to Parallel Port adapters made specifically for this scenario. They can run $10 to $30 depending on where you go. I recomend www.Geeks.com for those. That will allow you to plug an older printer in to a newer machine.
If it's made for a mac only, there should be a small circular port about the same size as a PS/2 keyboard or mouse. That is to connect to the Mac serial bus. This is differant than the barrel connector or brick used to supply power to the printer.
Hope this helps.
Oct 16, 2008 | Lexmark Office Equipment & Supplies
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP Color LaserJet 4550 Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
