Ice Cream Makers Logo
Posted on Sep 08, 2010
Hello! Can you say me access code to service menu (not to managers menu 8309) (my machine is taylor C 606).
Mohammed
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 11, 2017
Mohammed
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1664
Points
  • Brian Trinidad Mar 31, 2024
    Taylor 606 - Manager 8309 and Service 5231
1 Related Answer
Anonymous
  • Posted on Nov 19, 2010
SOURCE: I have a Taylor PH71-58 ice cream machine could
access code is 8333
Testimonial: "Thank you for the access code to my ice cream machine, this will help me a great deal."
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
4helpful
3answers
Where can I find a repair man for Taylor Frozen yogurt machine? I live in Los Angeles, CA zip code 90024.
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
2answers
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
4answers
Spares for Taylor 8756 ice cream machine
you must buy replacements from your local tatlor dist. 700-900$
You will find that responce from all of thier part suppliers carrier is a very well insulated company.
Top Taylor Ice Cream Makers Experts
vince
john h
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
