Question about Avery Office Equipment & Supplies
I have avery 5472 3/4" color coding labels. how can i load them into a lexmark t652n printer?
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Okidata - label printing alignment
You might try setting up Word for a 'custom' label since it offers that option.
I've done some strange labels by directing Word via that feature.
Posted on Aug 26, 2008
SOURCE: Printer labels do not line
The only way I could get round it was to type one page of the labels, then print on plain paper. Check with label size then go back to screen and individually change the labels that were misaligned. Then when I printed on to a label page it was correct. Time consuming but at least I didn't waste any labels that way, only paper.
Posted on Nov 22, 2008
SOURCE: Avery label printer 9100 won't print
I have the same printer and usually when this happens I am able to flip the lever on the side to put it into auto peel mode and push the feed button on the front and that usually works and makes the light go green. It was explained to me that if the label stock is old it will have a hard time recognizing it. Sometimes I have to pull out the labels and re-insert the labels to get them to work properly. I hope this helps.
Posted on Nov 24, 2009
SOURCE: AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Posted on Feb 11, 2010
How can i clean my lexmark t652n? it continually paper jams.
"continually paper jams" you need to replace the fuser kit
Oct 07, 2014 | Lexmark T652DN MONO LASER PRINTER...
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
Im trying to print avery labels but my printer does not have a setting for it
Normally support for printing Avery Labels is found within the application you are using to create the labels to be printed, i.e. in Microsoft Office Word or similar publishing programs. . . .Avery provide a Wizard extension to use in Microsoft Word to help you to produce and print on their labels. . . .See http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-Wizard-for-Microsoft-Office.htm for further details and to download the Wizard. . . .Note: You need to allow Macros to execute within Microsoft Word in order to use the Avery Wizard.
Sep 22, 2011 | Epson Stylus NX400 InkJet Printer
Kodak printer will not print on avery label paper. Have been on teck support with anurag s for about an hour and tried again to print labels.
Hi , i have been using avery templates and label paper at work for ages and always printed off without problems on my lexmark . I bought a Kodak however and all of a sudden I could no longer print off my labels , when I put paper in it just came out blank and said paper wrong size .I could not find any solutions at all and was tearing my hair out . I just kept trying different things and all of a sudden I changed a setting and it worked perfectly.When you go to print your label change the ' scale to paper size ' function to A4 and then it will print.
hope this helps
Feb 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
Lexmark won't print on Avery labels
The printer is expecting the label stock to be loaded into the manual feed tray, not the regular paper tray. If it does not sense anything in the manual feed tray it will not continue. If you are loading the stock in the tray, it may need to be pushed further into the try to trigger the sensor.
Jul 05, 2009 | HP LaserJet 4650 Color Printer
Want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
May 19, 2009 | Brother MFC 490cw Color Inkjet...
Printing avery labels
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Apr 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Making labels
there are software templates on the avery website. Maybe you can find the specific product you bought on the website and download a template that will help you print labels.
Mar 21, 2008 | Lexmark Z1300 InkJet Photo Printer
249 people viewed this question
Top Avery Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Bogbrush
Are you an Avery Office Equipment and Supply Expert? Answer questions, earn points and help others
