Question about Westward Electronic Digital Caliper Model 2za58
How to change battery in unit. - Westward Electronic Digital Caliper Model 2za58
Temperature in/out 911711; changed batteries on bothe indoor and outdoor units. Outdoor temp not registering on indoor unit.
  • Remove all batteries
  • Install batteries in outdoor unit and allow it to initialize and begin sending data.
  • Install batteries in indoor unit. You should see outdoor temperature displayed
If not, either unit or both may be defective
Aug 07, 2017 | Measuring Tools & Sensors
Changed battery and changed all detectors and they still cherp
Try installing all new batteries. Latest installs have the individual units also hard wired to each other so that when one goes off the others are triggered. When a battery is weak in unit it often causes the main unit to chirp along with some of the others in sympathy. If still no improvement and all batteries are brand new, then either get new units or disconnect the hard wiring between all units.
They will still work but without the nasty global feature.
Dec 22, 2016 | Home
Do I need to keep a power backup when changeing the battery
Yes you do
battery shops have a small unit the plugs into the system and keeps items and codes in place during the change over
talk with a battery shop and see where they connect the unit
basically it is a small 12 volt battery
Feb 15, 2015 | Cars & Trucks
How do i change battery on trumeter 5505e
The device is not meant to have the battery changed (?!).
However, I am going to drill out the holes where the screws would go and try and change them myself. It doesn't not make 'consumer' sense to me to have this unit without being able to change the battery. It has a 5 year battery life but I only need this unit once in a while so in 5 years I may only use it once or twice.
Jun 07, 2013 | Cameras
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
Kidde smoke detector without a door or tab for back up battery - where do I find the battery so I can change it. It has been beeping for close to 39 hours. Installer did not leave a users manual. (The...
Some smoke detectors are AC-only, so there is no battery. Dual-power units typically have the battery compartment on the back of the unit, where it attaches to the wall or ceiling.
Most units must be removed from their mounting bracket to change the battery, as the battery cover is on the back.
You rotate the unit about 1/2 turn counter clockwise, and it should come off the wall/ceiling. If it has an AC power connection, you unplug that so you can change the battery more easily.
Oct 16, 2009 | Home Security
I changed my Cmos battery & my laptop would not start after tha
Without battery, BIOS just gets reset to default and should not effect boot. There is a possibility that you failed to reconnect something important when disassembling the unit.
What exactly happens when the unit turns on?
Jun 18, 2009 | Dell Latitude C640 Notebook
Westward Electronic Digital Caliper Model 2za58 Logo
41 people viewed this question
Top Westward Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Westward Measuring Tool and Sensor Expert? Answer questions, earn points and help others
