Question about Refrigerators
There is no freezing in the freezer and air coming into the fridge is quite cool but light. I have cleaned the bottom coils last night and most of the frozen foods have been removed a day ago. I keep the temps on med. Incresing it didn't help. The fridge is 14 months old
  • Donald  Rowan
    Donald Rowan Sep 08, 2010
    More information is required to help you. Model Number, any funny noisees, can you tell if the compressor is running, is the fan in freezer running. What are the tems in the freezer or fresh food side ?????
    Help me Help you :)
    Don
    Mr Fix it
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Everything was fine and suddenly last night both the fridge and freezer started warming. Freezer is now at 45 and the fridge is at 55.
It could be as stated originally that it may be the thermostat. That was my problem. I had a Sears 18 cu top freezer. The thermostat was located behind the metal panel in the freezer. Take the panel off and it should be a round little metal cup that has 2 wires going to it. It was a cheap part, under $10. Just cut the wires, splice in and good to go. There are some pretty good videos on you tube for trouble shooting.
Mar 06, 2016 | KitchenAid Refrigerators
Whirlpool American fridge freezer FRSB36AF20/2 Triangle Warning light on and freezer not freezing. Fridge ok
Most common these symptoms point to a unit low on freon. The fridge gets its cold air from the freezer. So there is just enough freon for a good fridge temp but not to freeze water in the freezer.
Second would be the coils froze over due to the defrost circuit not working. Also check the conderser fan in the freezer. The cooling fan in the back bottom, if there is one, may have quit also.
Sep 27, 2014 | Refrigerators
Model number mfd256hew maytag refrigerator not cooling but lights on
HI,
1-Power off for 3 hrs. then again switch on and let it be completely cold.
2-Put away from wall.
Nov 20, 2011 | Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Jul 31, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
We let the fridge thaw for two days, cleaned it from top to bottom especially the coils and underneath. We moved it outside and used an air compressor to blow out the dust and dirt around the coils so nothing was damaged in the process. It works like a charm and probably more efficiently too. Before it had quit working it was freezing in the refrigerator part. So that was an indicator something was clogged. Moisture that collects and freezes blocks the air from circulating. The freezer worked great! But ice cream was too hard.  Now it's just right.
Apr 06, 2008 | Maytag MBF2256H Bottom Freezer...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
