Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I have a hoover steam vac LS 3600 and i attached the tool to clean my couch. the tool is sucking but no solution is coming out. i checked the hose and everything looks ok but no solution will come out of the sprayer.
  • Hoover Master
  • 17,129 Answers
There is a small pump inline of the spray unit. This is normally a coil type reciprocating type and most often this can be dirty or faulty.
So remove pump and check it on table to see if this works, if not clean or test coils for continuity. If not replace.
Posted on Sep 08, 2010
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I switch from tools to flooe on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi Cherie! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Jun 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I switch from tools to floor on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Have a hoover steam vac that wont **** up the water brushes spin
Look at the bottom, where the water comes out and comes back in? Is it filled with hair/dirt? It might need to be cleaned out where the water sucks up in at. Otherwise I would go to Hoover.com website for f.a.q.s or technical support.
else
If you find that your cleaning solution will not dispense, check that the tank is securely in the locked position. There is also a chance that the solution tank is empty, in which case fill it with cleaning fluid. Ensure that the recovery tank lid is firmly in place.
or
Prime the pump. Priming means to remove air from the system so that the cleaning fluid can flow to the tool. You "prime the pump" by attaching the tool to the hose and turning the carpet clearer to ON. Then put the tool on a hard surface or against your hand to block the suction. It may take up to 15 seconds to remove all the air. Once this is done, squeeze the trigger on the machine and begin to clean.
Thank You.
Jul 18, 2010 | Hoover Vacuums
No suction in new Hoover Steam Vacs
http://www.hoover.com/pdfs/manuals/F5914900.pdf hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac LS F5897-900
get a copy of the manual at this site
http://www.vacuums-cleaners-bags.com/
Aug 07, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
617 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
