Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
My father has i believe a jazzy 6 wheelchair and the lights keep flashing. There is no sequence of flashing, just flashes away without a break. The horn works, that's all. Wheelchair will not move at all. My father said he fell on joystick and it stopped working. The connecter from the joystick to other wire has four pins the two outside holes are round the the other two center holes are round ontop and flat at the bottom. Please Help. Thank you...
  • 692 Answers
Bobby check that the chair is not in freewheel first (you can push it and it will roll freely). If it is not in freewheel, try this--- turn the power off on the joystick then turn it back on and immediately push the jostick full forward until you hear a beep then immediately pull the joystick to the rear until you hear a beep then let it go to the center position. If the chair is in lockout it should take it out and the chair will operate fine. Now if that doesn't work I dunno. No seriously a continuous flash as you describe is the only indication of a lockout that I know of for the Pride chairs. If Medicare bought dad's chair then you can get a service company to fix it for him and they will bill Medicare for the cost of repair. Medicare will pay 80% of the costs and if Dad has a supplemental policy it will cover the 20%. Contact Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps
Posted on Sep 09, 2010
Testimonial: "Did what you said, no results. Looked at and changed batteries and chair started working. Bad batteries even though they were new. Thanks for helpin"
  • Randy Oldeen
    Randy Oldeen Feb 20, 2011
    hello bobbyb121 i have the same problem that u had at the beginning with my grandfathers 1113 ats wheelchair so even though u had new batteries they where still bad?
Jazzy wheelchair scooter 1450. Why does it go crazy with flashing (charging lights)?
Hi Emilee,
The lights flashing crazy, may mean you have locked out joystick. to unlock, try first, turn on joystick and push horn button twice right away. if that did not work, try turn on and push lever forward all the way wait until it beeps, then back all the way until it beeps again. that should do it. If not then count how many lights are blinking and how many times it blinks. consult owners manual trouble shooting guide for answer, or call 800-800-8586 Jazzy tech
Mar 12, 2016 | Health & Beauty
Why does my jazzy select six lights blink but wont go
The number of flashes indicate the problem. Go to Pride's website to download the service manual. It will tell you what the flashes mean and how to fix it.
Jul 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Unlock
Not enough info to really give a good suggestion. Flashing lights and no movement usually indicates that the batteries are very low. Testing the batteries is the place to start and go from there.
Apr 29, 2013 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy 1120 When I turn it on all the battery lights flash rapidly any suggestions
How many are flashing? There are 10 lights, if all are flashing (3 red, 4 yellow, 3 green) that indicates Code 10 and high battery voltage.
Apr 03, 2013 | Pride Mobility Products Used Jazzy...
Pride jazzy select turns on but when you try to move the battery light flashes 8 times then turns off.
Appear to be a problem with you control system. Check joystick module and power module connections. Look for frayed and damaged wiring.
Mar 24, 2013 | Pride Jazzy Select 6 Indoor Power...
My fathers jazzy 600 displays a wrench on the control monitor. It will not move backward or forward
I need to know how many times the wrench is flashing before I can tell you what the problem is Let me know
Apr 18, 2011 | Pride New Jazzy 600 Power Wheelchair by...
The controler cable cought on something and pulled out, breaking the connection between the two cables .. I cut off both ends and soldered the 6 wires togather .. Lights flash .. I took the controler apart...
Hello,visit:- www.alldatasheet.com its what it says alldata on everything,its free & you can download as PDF File save to your Adobe Reader + print for future ref.im disabled myself & know what its like to be stranded.Have a nice day Colin.
Nov 13, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
My jazzy select 14 keeps lighting up like its charging after its unpluged and the chair wont do anything
Can you tell if the lights are flashing a number of times then pausing slightly then flashing the same number again and so on? If not then check to make sure your not in "freewheel". The levers are behind each wheel If you are getting a flash code determine the number of flashes the codes should be in your user manual or goto Pridemobility.com and you can download a owners manual for that chair. Hope this helps
Aug 22, 2010 | Pride Mobility Products Jazzy Select 14 XL...
Lights blink in sequence of 7 when turned on
The 7 flashing lights indicates the VSI controller joystick has an internal fault requiering replacement. Call your local mobility store that does repairs or willing to sale the controller joystick to you. Inquier if you health insurance will help. These VSI controllers can cost upto $1300 - $1600 new. If you live in Utah you can try the Intermountain Homecare Custom wheelchair shop. Hope this helps.
Feb 02, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Jazzy 115 will not move. Controller has 3 red and one amber bar flashing
Pride doesn't make a Jazzy 115. Please check your chair and owners manual to get the correct model so we can help. How old is the chair? The flash codes you are getting depend on the model, year it was born, and the tkype of controller installed.
Also, the flash code should be literally, flashes. 2 lights flash twice, stop, then go again, etc. They all mean something, so repost with more info please.
Jul 07, 2009 | Electric Jazzy 1115 Power Wheelchair
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
216 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
