Question about LG WM1814CW Front Load Washer
Goes Through Wash Cycles Empty Or Full Stops At Spin And Says UE About 4 Minutes Before End
    President:
  • 1,932 Answers
An UE Error Code is indicative of a “Unbalanced Error”.
This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Thank You
Posted on Sep 08, 2010
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
I have an LG WM2487h*ma model. It trys to spin during all cycles but turns a few times then stops, then trys again. Never gets to full spin capacity. Tried small load, and big load. Watched during a...
Hi!
I think there is nothing wrong with your washer. The UE error means Unballanced Error. This error comes up in two cases: 1. the load is distributed unevenly in the drum or 2. the machine is not properly set on an even surface (floor).
Of course, it could be a third case possible, but very unlikely, when the ballance sensor itself is malfunctioning and have to be replaced, or the spring and dampers are worn out and also have to be replaced.
Hope it helped!
Best regards
Aug 09, 2011 | LG WM-2277HW Front Load Washer
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Ue error during spin mode (b4 spin up happens) empty. wm3677hw
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. Also you have mentioned that the drum with full load has no such problem. It means that the drum cannot manage its weight in that position. So the problem might b adjustable easily. Try to remove the top panel and check for any slight movement in the position of the drum. Leaving it continue this way might increase the probability for the error to be repeated with the load. Will add some links related to internal diagrams of this model when i find some that might help you to check the drum inside.
Good luck with the machine.Please do rate my solution and post comments and results.
Sunny.
Apr 20, 2009 | LG WM-2077C Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
LG WM1814CW Front Load Washer Logo
509 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
