Question about Canon PowerShot SX120 IS Digital Camera
Lens error/ restart camera message appears. shop says camera may have been dropped but it wasnt.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 08, 2010
"lens error turning off camera.
If the camera was dropped it can somehow seize the lens related parts since they are mostly made from plastic. It is also possible that particles like sand grains can go between the moving parts of the lens and seize the mechanism. Either case the repair could be expensive and may not worth having it done.
Feb 24, 2011 | Canon PowerShot A495 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Aug 19, 2009 | Canon PowerShot A480 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart Camera
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon PowerShot SX120 IS Digital Camera Logo
594 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
