Question about Bosch Ovens
My built in Bosch oven has a self clean mode that starts up properly and then after 4 minutes the digital screen on the oven says"error 41"! Could you please tell me what this means! The oven is a few years old only! Thank you
  • mel_kapecki Sep 08, 2010
    I do not understand this answer! Please be more specific. This answer given to me has so many mis-spellings , it is hard to understand. Thank you!
  • 944 Answers
The code actually means there is some problem in the lock mechanism.unplug the range at least for 6-8 hours.So memory and internal battery a reset.Spray some WD40 into the lock mechanism and let it sit over night.So the lock mechanism will work properly.The self-clean function will not be activate if it shows this error.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
    Genius:
  • 1,417 Answers
what this error code simply mean is that there has been a loos of wire some well or an over flow of liquid substance located on the panel of the oven by the screen sensor.
please fill free to get back to me for more information or way out
hope this help?
thank you and thanks for using fixya.
I have Bosch self cleaning oven, door will nit open and control panel says error 43 what do I do?
SOURCE: Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Posted on Apr 30, 2010
Error 43 on Bosch range how can open the oven door
Mar 26, 2018 | Bosch Ovens
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
How do I start bosch exact temp self cleaning oven
My Bosch is also self-cleaning. If you press and HOLD the 2 buttons Bake and Broil that will lead you through the process. It starts by beeping at you- don't give up. :D
It will remind you of several things:
Choose length of time (4:00 is standard)
Remove the racks (self-cleaning will make them 'sticky'
and so forth
Keep pushing Start if you are comfortable moving forward.
Hope this helps!
Apr 28, 2012 | Ovens
I have error code E106 on my self cleaning Bosch oven
I had same issue - A simple switch off/on at the main breaker for the oven was enough to resolve it.
Mar 01, 2012 | Ovens
My oven show lock sign and i can not open it
If its a self cleaning oven it might be in clean mode. It usally takes 4 hours to clean. If its been more than 4 hours, it might be an electronic issue. Try unplugging it for about 5 minutes and plugging it back in.
May 23, 2011 | Electrolux 30" Built-In Single Electric...
I'm trying to clean my Bosch oven, model number HES5052U, and twice now it gets 30 minutes into the self-cleaning cycle and then it shuts down... flashing Error 41. Everything seems to run smoothly until...
Allow the oven to cool before running self-clean. Always wipe out loose soils or heavy spillovers before running self-clean. If oven is badly soiled, set oven for the maximum self-clean time.
Here is the manual with "troubleshooting". Hopefully, it will help!
Operation Bosch HES5053U 31 100
Jun 29, 2017 | Bosch Ovens
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Oven cleaning
Error 41= Data cable shorted to ground//remove cable and reseat
Jan 01, 2008 | Bosch HBL 442 / HBL 446 Electric Single...
Ovens Logo
249 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
