Question about Fisher Ovens
Fisher Scientific Isotemp Oven model 655F. The coils won't heat above 25 degrees celcius. it should be heating above 100.
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Not heating up
Hi.
I suspect you may have a faulty oven element, which is breaking down as it gets hotter, disconnect element and try if ,if it does not trip, then element is faulty
Posted on Nov 22, 2008
SOURCE: Oven won't heat.
Thanks for the tip. Had the same problem, everything seemed to work except for the heating elements. Removed the vent cover inside the door just below the control panel. Found the reset button and also found one of the large black power wiires had come loose from its connector. Turned off the power at the breaker box, checked for voltage with a meter and re-attached wire connector with insulated pliers. Oven works now. Lets call this failure "poor workmanship at Dacor".
Posted on Feb 03, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
dmftrucker
  • 1922 Answers
SOURCE: Set oven to pre-heat to 350; won't go above 100
could be one of 3 problems: missing 240volts and only have 120volts(one leg out)/bad element(chk for "hot-spot") pitted and discolored-it will soon break there/or the thermocouple is bad that senses oven temp
Posted on Jul 27, 2009
I just had my igniter replaced on my Kenmore oven, now the temperature foal won't go above 260°, the oven is heating very hot, but the dial won't go higher. Can this be reset?
Your oven is probably in Celcius mode - try holding bake (or broil) for 3 seconds (after cancel) to toggle. If not, the owners manual will tell you how to switch back to degrees F.
Sep 16, 2015 | Kenmore Ovens
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My Thermador RDDS30VRS only heats up to 230 degrees
If you have the use and care manual, check to see if your unit has the option to change from farenheit to celcius. If so, make sure yours was not accidentally changed to celcius.
Sep 07, 2011 | Thermador SEC301 Electric Single Oven
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
Oven wount go above 100 degrees or get hot
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 11, 2011 | Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Ovens Logo
445 people viewed this question
Top Fisher Ovens Experts
Dennis Boxerman
Richard
Richard
ray gallant
Are you a Fisher Oven Expert? Answer questions, earn points and help others
