Question about Craftsman Electrical Supplies
Exhaust red hot,why? - Craftsman Electrical Supplies
  • 395 Answers
It is quite normal for the pipe/muffler connected to the engine exhaust port to get very hot, especially when the engine is working hard running at speed under load. During daylight it is usually not noticeable, but at night it will visibly glow up to a bright red.
Posted on Sep 10, 2010
Rear jug getn hot 2 min after start up exhaust getn red hot...stage 2 jet kit..vance&hines exhaust .no baffles 43000 miles
glowing exhausts indicate valve timing, ignition timing or lean fuel mixtures
AS you have altered the jets I would be looking at air/fuel mixture for the rear pot
It is probably the same for the front pot but with an air flow on the exhaust pipe you will not see it getting red
Jan 16, 2016 | Red Motorcycles
Exhaust red hot on a bmw
There is raw fuel entering the exhaust system or the exhaust is plugged
Jan 06, 2016 | BMW Cars & Trucks
Exhaust gets red hot when running
Have you checked for any fault codes, get the car checked for codes, if it is getting that hot it could cause a fire.
Apr 18, 2014 | Vehicle Parts & Accessories
Westwood 1300s red hot exhaust
Get carb. adjusted, way to rich.
Mar 30, 2014 | Briggs & Stratton Garden
Exhaust manifold and pipe glowing red hot hyundai accent 97
Exhaust Glowing Red Hot
Start over--you do not have the timing
belt on correctly
Dec 06, 2012 | 1997 Hyundai Accent
WHY WOULD MY CAYLATIC CONVERTS GET HOT RED AFTER CHANGING PLUG AND WIRES ON A 96 LINCOLN /
You replaced the Plugs Wires in the wrong
firing order ?
Sort of creates a timing issue & causes the
exhaust to get hot
Other causes,vacuum leaks in to exhaust
or rich fuel mixture,but not to the point of red hot
Aug 03, 2011 | 1996 Lincoln Town Car
Car starts but has no power and exhaust pipes get red hot
your converter is blocked needs to be changed,unless exhaust system is damaged and causing restrition.
Apr 18, 2009 | 1992 Cadillac Seville
Red hot exhaust manifods
Make sure that your catalytic converter and exhaust is not plugged..Also check for propper map sensor operation,the reading that the map sensor supplies to the pcm is used to adjust ignition timing and fuel delivery.If the timing is being retarded to far , the exhaust exiting the cylinders will be extremly hot and will produce the effect you are having...Good Luck...
Aug 22, 2008 | 1998 GMC Sierra
Electrical Supplies Logo
527 people viewed this question
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
