Question about Steinberg Cubase SX3
Why is cubase SX unable to make a simple audio recording when all the setup procedure has been correctly followed. PC is one year old running vista.
    Problem Solver:
  • 23 Answers
Vista's your problem
Posted on Sep 16, 2010
I just bought this mixer and can't seem my existing Cubase recording software to recognize it for recording. Do I have to run the mixer thru my existing interface or can the Cubase setups be modif
The mixer allows you to use the USB connection for recording without having to use an additional interface. Make sure that you have all of the proper drivers installed for the mixer. Regardless of whether you're using Mac or PC, you should be able to see the device in your list of available Audio Devices. If you do, you need to adjust the proper settings in the Cubase Audio preferences to make use of those inputs.
May 29, 2013 | Mackie PROFX12 Professional 12-Channel...
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
CANT GET MY EMU 0404 USB TO RECORD !!!!
you need to update yo sound card with vista
Jan 20, 2010 | E-Mu 0404 Sound Card
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
65 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
