Question about Health & Beauty
John Abdo's Belly Buddy System - Health & Beauty
I have a 2013 keystone cougar 327res and the belly pan is full of water...where should i look for my leak?
This is not just for your camper, but general troubleshooting.
Drain the water from the belly pan. Hook up water supply to shore water source. With water source turned on, allow some time, 1-4 hours, and check if water has returned to belly pan. If water is present then the problem is with the fresh water system. If no water, either it is a small/slow leak or the problem is not with the fresh water system. Next test the grey water tank by pouring some red food color into the shower or sink drain. Flush it into tank with water. Again, wait for some time, maybe over night, and then check for red water in the belly pan. It may take longer for the leak to appear as the grey water tank does not have pressure. If no water, check the black water tank with green food coloring and same technique. If there is colored water, red or green, in the belly pan, then the leak is with associated with the grey or black water tanks. If no water is present after these tests, then the leak may be very small and it may take days or weeks to have water re-appear. In any event, clear water is fresh water system, red water is grey water system, and green water is black water system. With any of them, checking the tanks themselves and all pipes and connectors to/from should find the leak source. The last possibility is that water is entering the belly pan from a roof or vent leak. Check to see if water returns to belly pan after a good rain. If so, the water may be clear or slightly dirty. If it is a roof leak, I have found the best repair is to use Peel and Seal roll roofing It is light weight laminated aluminum and self sticking. Cutting and applying narrow strips 4-6" wide, will seal any caulked area. It costs $95 (3' x 33') at Lowes. A 30" motor home can be completely covered with three (3) rolls, in half a day. I have re-topped 5 motor homes (one 7 years ago) and no more leaks on any of them. The product was developed to seal the roofing joints of mobile homes. Topping should last 15+ years.
Oct 05, 2016 | Keystone 2013 Cougar 327RES
Change my golf buddy from metric to yards.
Hi John,here's a link on your golf buddy,it tells you how to change from yard to metric.Chapter 2,section 19.
Sep 28, 2016 | GolfBuddy Golf Buddy VOICE GPS
How to loose a fat belly
WHAT IS THE BEST WAY TIO LOSE WEIGHT FROM HOME WITH OUT BUY ALL THAT DIET PILLS
Jan 02, 2014 | Android Apps
Inser cart sim of on of on
Hi abdo,
You will have to get your phone flashed(install new operating system) from a phone repair shop, that will surely solve your problem.
please vote me and rate me if i solved your problem,
Regards,
Salman
Feb 13, 2011 | Samsung SGH-G600 Cellular Phone
Hydraulic problem
Check your hydro preasures,pump could be going out,also could be in your relieve valve which will be cheaper,hope that is your problem because of the cost,Sound like you know alot about it, and trust you have a high mechancal ability,I have a hunch it could be in you valve, hope this helps,
Sep 02, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Goats Belly Removal
Get and aftermarket exhaust system for it, and follow the instructions.
Jun 09, 2009 | 1998 kawasaki VN 1500 Vulcan Classic...
Health & Beauty Logo
146 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
