Question about KitchenAid KTRP22EK Top Freezer Refrigerator
Freezer too cold do i turn dial higher or lower to adjust
  • KitchenAid Master
  • 43,501 Answers
Turn the dial lower to make it warmer...
heatman101
Posted on Sep 11, 2010
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
Hi, If I remember correctly, make sure the freezer control is set to on, otherwise neither will cool.
You need to give it 24hr for temp to settle, then check to see if freezer temperature is 0? to 2? F (-17? to -16? C).
Turn control to next highest number if too warm.
Turn control to next lowest number if too cold.
Allow 5 to 8 hours for adjustments to take effect.
Check to see that fresh food section is 38? to 40? F (3? to 4? C).
Hope this helps
David
Mar 02, 2018 | Amana Refrigerators
How do you "warm" a Midea fridge do you turn dial higher (5) or lower (1)?
The higher the number, the colder the fridge gets. Is it too cold in the fridge?
Apr 27, 2014 | Midea 1.4cf Refrigerator White
Lower freezer not getting cold on LG Model LFC25760ST
What number do you have the dial set at? Try turning it to a lower or higher number.
Sep 04, 2012 | LG Refrigerators
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Temperature
If this unit has a control it would be located on the outer left side in the lower right hand corner. There would be a dial, the higher the number the cooler the temperature. Many of these chest freezers did not have an adjustable control.
Apr 13, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Freezer and refrig both too cold. Adjusting the
If turning the freezer cold control (thermostat) all the way doesn't turn the compressor off then the thermostat is bad.
Dec 11, 2009 | Amana ARB8057CSL Bottom Freezer...
KitchenAid KTRP22EK Top Freezer Refrigerator Logo
56 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
