Question about NRS Ariel - Toilet - Two-piece - Diana - 2003
Manual for Ariel "Opal" 8019BLK Toilet with Dual Flush - Having trouble with installation
  • 3 Answers
SOURCE: New American Standard Flowise toilet won't flush
Same thing here. We have tree roots that occassionally grow into the sewer line out in front of the house. About every 6 months we would have to snake the whole line. We started buying Root-X which keeps the pipes clear of roots and which does not harm the pipe. Once a year we put it in there and leave overnight. No problems anymore. We get ours on EBay.
Posted on Apr 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
  • 11 Answers
SOURCE: Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
Posted on Dec 16, 2009
  • 349 Answers
SOURCE: how do i set the flush levels for a glacier bay
http://www.homedepot.com/catalog/pdfimages/f9/f9b2dcf2-bfa0-4622-94d9-7b326c22eb1e.pdf
Go to page 5 & 6 and it will guide you through setting levels.
Posted on May 23, 2010
woobie dog
  • 1273 Answers
SOURCE: How can we stop our
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Posted on Jan 16, 2011
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
Hi all, I have a Jacuzzi SWP-1 Perfecto Dual
Hi, Go to amazon and look for replacement parts.... here:
Jacuzzi SWP2959 Perfecta Dual Flush Two Piece Elongated Comfort Height... I hope this was helpful.
Mike
Aug 15, 2013 | Jacuzzi Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Feb 23, 2013 | Home
How to install arial opal toilet (af-80190the odilia
Where is the proper flange placement on an odilia af-8019 before installation
Jun 17, 2011 | NRS Ariel - Toilet - Two-piece - Diana -...
VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Pegasus Dual Flush Toilet - How to repair damaged handle
any good plumbing supply company will help you. " Furgoson " i think thats how you spell it.
Jul 18, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Unable to fit a toilet seat
Hi neenyc02.
I'm Harvey the Master Plumber.
Your problem is: The cistern to your toilet is behind a wall. and you can't fit a new seat
I'm having trouble visuallising your problem. For the average toilet there are only two sizes, round front and elongated. Compost and other special types are usually made to accept one or the other. If we're talking about a small marine tupe or such it would still install very much the same way. If you could upload some clear pictures of your problem it would help a great deal. In any case you will need access to the bolt holes (top & bottom).
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 26, 2008 | Toto Aquia II Dual Flush Toilet
NRS Ariel - Toilet - Two-piece - Diana - 2003 Logo
204 people viewed this question
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
