Just got an HP out of the box - HP Pro 3130 with an HP LA2405WG 24 Inch Monitor. Everything is pluggen in properly - triple checked. I turned on the tower and then the monitor. When the monitor comes on it scans for Display Port, DVI and VGA and comes back saying no signal for each and the monitor has a message that it is going to sleep and immediatley goes to sleep. Is anyone know how to help me or have run ino the same issue?
AtlasIT
  • 72 Answers
SOURCE: cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
Posted on May 19, 2009
dncholas
  • 222 Answers
SOURCE: how can i go dvi - hd to vga to my hp a1010n tower
DVI - VGA cable adapter. One side is DVI and the other is VGA. Connect VGA side to your pc's video output and then plug the DVI cable to the other
Posted on Nov 27, 2009
  • 345 Answers
SOURCE: monitor shows VGA no input signal DVI no input
This sounds like a video card driver issue or the card it self. Make sure all cables are plugged in snug. Once done try to boot in to safe mode by restarting the computer and while it is starting keep on tapping key F8 and choose safe mode. If this works it is driver issue. If nothing happens it is the card it self. Might have to take it to a authorized repair shop. Hope this helps.
Posted on Feb 15, 2010
shoyo
  • 573 Answers
SOURCE: I turn my computer on
May be in "RAM". Did you tried by removing the RAM. If not try this remove the RAM and wipe up the dust and fit it again. And If you do not get the single initial beep, that means the motherboard is not working and that's why you don't get a display. No initial (POST) beep indicates a hardware problem, usually (but not always) with the power supply or motherboard.
All the Best!
Posted on Sep 15, 2010
puertobori
  • 7733 Answers
SOURCE: When I turn my computer
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Aug 15, 2011
How do you set up the Asus VE247 24" LCD monitor on a Macbook Pro?
I had this problem with windows using HDMI. try letting the mac boot up all the way before inserting the HDMI.
if this helps please take time to rate
Feb 01, 2013 | ASUS VE247H 24 inch Monitor
Dell Desktop monitor has flashing dots, black and white, all over the screen.
Check have you installed graphics driver properly in order to as per your monitor and as per your system or not.
Jun 20, 2012 | Dell U2410 24 inch Monitor
When I turn my monitor on I get an unusable signal box on the screen. The Internet provider says the Internet is functioning at the modem but I get nothing on the screen. I also have a wireless router...
It's not an Internet related problem. It's problem with monitor.
Please check
1. If monitor cable is connected properly to the tower(CPU)
2. Check the [ I/P ] button and try to press it to toggle between interlaced and progressive scan mode
Sep 12, 2011 | HP Computers & Internet
Hi, I've got a brand new monitor - HP Compaq 2405wg. A good monitor overall, but with a crucial flaw: the issue is most visible with black lines on white background - they seem to have a light grey...
so you plug this display in to any other DT or LT pc
and it fails too?
if yes, the display is bad
if not your PC is borked. (needs service, )or bad display card.(chip)
or drivers wrong or bad. up date the video car. drivers now.
we cant do both here, but you can test this why and tell us
which part is bad, display or PC>
Mar 25, 2017 | HP La2405wg 24 inch LCD Monitor
I installed an ASUS M4A78LM Motherboard also with a AMD Triple core processor. 4GB RAM. 32bit Windows XP. The computer starts up nicely, but the monitor doesn't turn on. Everything seems to be plugged in.
Make sure that you VGA/DVI card is in the motherboard slot properly, also just check that your power cord and plug on the back of the P.C is connected properly.
Thanks
Jason
Oct 14, 2010 | ASUS M4A78LM (90MIBB70G0EAY00Z)...
I am graphics pro looking for 24 inch HD monitor display w standard aspect ratio
Look on www.ebay.com for a "refurbished" and '24" and "inch" and "LG" and "LCD" device.
Apr 02, 2010 | LG W2453V-PF 24" LCD HD Monitor
24" DOA Soyo Monitor
What size monitor were you using before? If you were using a smaller monitor and everything was fine maybe this new monitor is out of range for the graphics card. I've found that not all graphics cards, especially older ones, will not run a monitor as large as 24 inches. If you can, connect this new 24 inch monitor to a computer with a more powerful graphics card. If it works then you will know that the problem is with your computer. Also connect your old monitor and go into control panel and see what range and resolution your graphics card will support. You may need a more powerful card to run the new monitor.
Jan 11, 2009 | Soyo Computers & Internet
Computer Monitor Compatibilty
Dear nicktsa
You need to put either new dispaly card or AGP card in dell pc (it supports) to get proper resolutaion of monitor
thanks
Gizmo
Oct 15, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
