Question about Maytag SkyBox MBV1976A Beverage Dispenser
The compressor is out. who can i get to fix it or where do i buy one. IS IS EASY TO INSTALL?
  • Maytag Master
  • 43,501 Answers
You need a pro to do that and it is a real pain in the **** to do...
heatman101
Posted on Sep 11, 2010
I can't get the fridge cold. I have connected to ac power. Everything else is working. The van is not level. How level does it need to be for the fridge to work? Would it make a difference on gas?
Check to see if compressor is running ,if not then you might have a bad relay or even a bad compressor. You can buy a hard start kit at any hvac supply house and install on compressor and see what happens.
They are very easy to install with wiring diagram on the kit itself
Jan 30, 2018 | Refrigerators
COMPRESSOR WILL NOT RUN
the cheapest fix may be the start/run capacitor for the compressor
have a technician check it out before you consider a new compressor
compressors are extremely expensive to buy and install and the total cost should be considered against the price of a new replacement unit.
Sep 01, 2015 | Refrigerators
Click buzzing and click coming from unit mounted to the compressor every couple of minutes. freezer not cold enough. Runs constantly.
Often replacing the temp relay and current relay on the compressor will solve the issue. You can buy what is called a 2 in 1 compressor control... easy to install and inexpensive. It just may work!
Jul 28, 2014 | Amana Refrigerators
2007 range rover suspension fault max speed 30mph
Stop letting people talk you into cr@ppy springs - the vehicle has a EAS for good reason.
After checking the air tanks and air lines for leaks do the following:-
1- get a new compressor or get a compressor repair kit plus a new relay switch - easy install + if that works - fine, if not
2- purchase new US made air bags from Arnotts and check the struts when replacing the bags - if that works - fine - if not
3- check & replace the 4 EAS sensors.
The only other fault could be with the computer module itself.
installing springs is a loser's fix - you might as well just go buy yourself an ox wagon.
Nov 18, 2012 | Cars & Trucks
I have a 1995 pontiac Bonneville compressor is locked up and broke the serpentine belt need to fix please help thanks Ron
Most cars have an option to buy a belt for a car with or without Air Conditioning. I would check first if your car offers that option (then if you don't need AC you can just buy the other belt and not have to fix the compressor). If you need AC you will have to buy a new compressor (local junkyard is your cheapest bet). I would have a mechanic install either the new belt (to make sure no other pulleys were bent when the belt snapped) or the compressor (some AC lines can be difficult or dangerous to repair or replace). Good Luck!
Jan 11, 2011 | 1995 Pontiac Bonneville
Air conditioner compressor making a knocking noise while running.i read that oil needs to be put in it if so where and how or do I need to plan on replacing the compressor
Get a can of R134a refrigerant with sealant and oil and add with a hose.
Can buy at Walmart for under $30.
Buy the conversion from R-12 to R134a kit if you need to.
Sometimes adding a few ounces of oil will quiet the compressor but you have to try.
Compressor is probably a few hundred dollars to replace, so try the cheap solution first.
Jul 04, 2010 | Cars & Trucks
Will not blow cold air
sounds like your ptc overload relay on the compressor needs replacing,they are not that expensive and easy to replace,simply by removing rear cover on the unit,removing the spring clip and unplugging the part off the compressor,then just reverse the procedure to install the replacement component
Apr 26, 2010 | GE Profile 24.6 Cu. Ft. Top-Mount...
Compresser wont start
Buy you one of those starting capacitor and load protection assembly. Available in your local ac supply. They are easy to install and reasonably cheap( about 20 bucks or less). The compressor should start. We use them when installing new compressor of if the compressor wont kick in. They work almost all the time.
Mar 06, 2010 | Samsung RM255LASH Side by Side...
How to reroute your serpetine belt on 94 taurus cause the ac compressor locked up
u do not reroute the belt u buy an ac delete pulley, remove the compressor and install pulley where compressor used to be, contact ford for the pulley. very easy job.
Sep 14, 2009 | 1994 Ford Taurus
Compressor doesn't stay on?
It could be anything, even cleaning the grill and change or clean the air filter might help. Does it get cool or does it warm up? The most likely problem is the starter capacitor and they are easy to install and cheep too. Let me know if you want the site to buy them at, if you have a test meter let me know and I can tell you how to test it before you buy parts. And thanks for using Fix-ya and please rate this free question if it helped, and get back to me if you need more help
Avid101
Aug 20, 2009 | Heating & Cooling
Maytag SkyBox MBV1976A Beverage Dispenser Logo
41 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
