Question about Garden
It will not pick up mown grass, either wet or dry.
  • 183 Answers
Check the blade! Your mowers blade is either worn out or installed upside down. The shape of a mower blade creates a vacuum or lift. The leading edge of the blade (sharp edge) should be parellel to the ground, while the trailing edge of the blade should rise up at about a 45 degree angle. This creates lift. As a blade wears, not only will the leading edge get dull, but sand and dirt cause the trailing edge to wear and reduces the vacuum effect. An upside down blade (easy to do) will just smash the grass and won't create any lift.
Posted on Sep 08, 2010
My Husqvarna SRD 17530 when I cut my grass I have set up as high as it will go and it will plug up with grass..
wet grass will stick to the inside of the deck. try to clean it real good and let it dry. try not to mow in wet grass if possible or it will happen again.
Apr 13, 2017 | Husqvarna Garden
When mower starts cutting the grass med.to high it bocks and wont cut
Make sure the grass is dry, not wet from due or resent rain, also have good sharp blade and full RPM.
Most important "Don't let the grass get too high.
Sep 05, 2016 | Garden
Won't pick up gas
what kind of mower and size and model is it.
Sep 28, 2014 | Briggs & Stratton Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
I'm looking for a playmat that I can put on a slightly wet grass
There are playmat that have fabric on top and a nylon or plastic at the bottom and it keeps the playmat dry.
Try this:
http://www.theportablebaby.com/playmat.html
Feb 18, 2013 | Baby Gear
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Hoover floor mate 500
If you mean the footswitch that shifts from wet to dry, trun the machine over with the brush assembly removed. There is a black rectangular oush button on the left side. This is the wet/dry switch. Make sure it is in contact with the white post to the left of it . It is the indicator that moves when you step on it. Push the button all the way in and out until it latches. After that it should work OK. Hope yhis helps.
Kirk Thompson
San Juan, PR
Aug 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
