Question about Fagor Washing Machines
Solucionar problema C03 - Fagor Washing Machines
Cogz
  • 1326 Answers
SOURCE: Check printer E 03-10
Don't know what you are asking? I only understand English, but the error code means that one of you corona wires are arching out they need to be cleaned or replased.
Posted on Apr 30, 2008
SOURCE: el lcd lg w1934s solamente prende por 3 segundos y
Son los inverters, tenes que cambiarlos, estan al frente del monitor, hay que sacar la tapa del frente y reemplazarlos.
Posted on Feb 07, 2010
  • 23 Answers
SOURCE: no tengo red ni sonido en mi hp dx2300
usa antivirus y escaneala tienes virus www.avast.com es gratis los puedes bajar de la pafina www.download.com y busca spyboot searh and destroy esos te pueden ayedar alguna duda tony30_2_1@yahoo.com
Posted on Feb 25, 2010
  • 55 Answers
SOURCE: riso graph GR3750 marca falla
"Risograph GR3750 marks to fault T11. I need consultation to solve this problem. Or it is necessary to call to technical support?"
Error T11 means: Call service.
Here some details of the error which may help to solve it: Pressure Control Motor Lock • In 100ms from turning ON of the pressure control motor, the encoder sensor cannot detect a pulse. • In 5 seconds from turning ON of the pressure control motor, the pressure centering sensor is not turned ON/OFF. • When the fuse of the main power board is gone.
Posted on Apr 29, 2011
seeker5211
  • 1089 Answers
SOURCE: MI IMPRESORA HP M1005, ME
Get the scanner/copier assembly replaced. If printer is under warranty call HP. If not call a local repair shop.
Posted on Aug 05, 2011
Mi palca madre de una hp dc 5100s me manda 9 pitidos y no se que sera me pueden ayudar
Se puede extraer en este enlace http://support.hp.com/us-en/document/bph07107 sobre c?mo solucionar su problema CV placa base.
Si se sigue produciendo el problema, buscar un t?cnico inform?tico para comprobar en su ordenador.
Jun 04, 2016 | HP Compaq dc5100 Small Form Factor PC...
COMO REPARO UN MICROONDA PANASONIC CON ERROR H98
H97, H98 o H99 significa que hay un problema con el inversor, magnetr?n, o el circuito de programaci?n digital.
Debido a las tensiones letales utilizados y producidos, no se recomienda que una persona sin experiencia de trabajo en estos. Yo recomendar?a que se ponga en contacto m?s cercano de servicio autorizado de Panasonic.
Soluci?n de problemas de circuito inversor (U) y Magnetron
Este horno est? programado con un sistema de auto diagn?stico c?digo de error que le ayudar? a solucionar problemas, H97, H98 y H99 son el fracaso y el inversor siempre magnetr?n ?reas problema en el circuito. Esta secci?n explica los c?digos de falla de H97, H98 y H99. H97, H98 y H99 aparece en la ventana de visualizaci?n poco tiempo despu?s de clave de arranque es presionado y no hay oscilaci?n microondas.
Forma alternativa para solucionar el horno con aire acondicionado Ampere medidor utilizado.
H97, H98 y H99 aparece en la ventana de visualizaci?n un corto tiempo cambiar clave de inicio es presionada y no oscilaci?n de microondas con amper?metro de CA utiliza para solucionar problemas.
Compruebe filamento del magnetr?n abiertos o en cortocircuito a la carcasa antes de proceder a determinar un buen magnetr?n.
Espero que esta informacion le sea de ayuda (recuerde valorar esta respuestas gratuita).
Sep 20, 2011 | Microwave Ovens
Tengo una impresora EpsomTX300f tomando fotocopias me imprime pero me produce una sombra en toda la hoja, esto me la hace muy lenta como hago para solucionar este problema. Agradesco su pronta ayuda.
Que tal.
Este problema puede ser causado por varias cosas. Entre ellas una mala configuración de los drives de la computadora, trata descargandolos desde la pagina oficial de Epson. También puede tratarse de un problema con los cartuchos algún defecto de fabrica(pequeña fuga). Si los cartuchos son rellenados, puede que no sean reconocidos de manera correcta por tu impresora.
Saludos.
Aug 28, 2011 | Office Equipment & Supplies
Mi camara canon powershot A3100 IS se apaga automaticamente y aparece en la pantalla se ha detectado un error. debe reiniciar la camara y yo no se como solucionar eso porque no he podido reiniciarla. como...
TENGO UN PROBLEMA CON MI CAMARA POWER SHOT A 3100 IS LA MISMA PONE EN LA PANTALLA SE HA DETECTADO UN ERROR DEBE REINICIAR LA CAMARA DIGAME COMO SOLUCIONAR ESTE PROBLEMA MI CORREO ES josemm22@yaho.com
Aug 28, 2011 | Canon PowerShot A3100 IS Digital Camera
No puedo imprimir las factura de My money 2004 Invoices My money2004 no print
Esto podría ser un problema de compatibilidad de software. Por favor, póngase en contacto con el Centro de Soporte Técnico de Lexmark para solucionar aún más este problema.
Nota: Esto se traduce utilizando translate.google.com.
Jul 25, 2011 | Lexmark X2600 InkJet Printer
Picture distortion on right and left sides of screen.
si tienes un tv pantalla plana con problemas .- primero tienes que indicar la marca y el modelo del mismo para poder ayudarte dandote consejos utiles para solucionar tu problema .- atentamente : roro8228@hotmail.com
Mar 29, 2011 | Televison & Video
Ola gostaria muito do manual do audi A4 modelo 2000. Pois o que eu achei e em ingles! Tambem gostaria de solucionar um problema no meu audi. Toda vez que piso no freio ele apita, faz um barulho de...
Acho que posso, o que voc? menciona ? o som do "grito" no freio quando o pedal. Poderia ser alguma sujeira na pastilhas de freio or're provavelmente j? passou e est?o se deteriorando outros componentes do sistema.
Sugiro remover os freios e revis?o, tomar vantagem de dar um ambiente limpo e mudar o que precisa ser mudado. Desculpem o texto, mas utilizar um tradutor para isso.
Mar 09, 2011 | 2000 Audi A4
Formateo de una olympus ws-100
susede que un amigo formateo la grabadora digital olympus ws-100 desde el pc y al momento ya no es posible utilizarla nuevamente, alguna solucion.... agradeceria una respuesta de como solucionar el problema
Sep 09, 2009 | Olympus WS-100 Digital Voice Recorder
Washing Machines Logo
298 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
roeb
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
