Question about Zebra Eltron P310 Thermal Printer
My Eltron P310 card printer pulls in the ribbon alongwith the card, past the print head. Thanks for any advice
Posted on Oct 03, 2010
  • 38 Answers
Got the same prob too(aged printer n its internal system)... but i noticed that actually 4 things happen, (my situation)
1.my card are not blank/new/perfect condition.
2.my printer need to turn off then turn on again.
3.my pc need to turn off and on again
4.setting or file that are suppose to print are not in correct format/setting( check please).
hope this solve your n others prob..
Posted on Oct 27, 2013
3 Suggested Answers
  • 54 Answers
SOURCE: printing special effects from corel draw on Eltron p310
Try looking for an option in printer driver Graphics settings which prohibits black panel printing
Posted on Nov 17, 2008
  • 31 Answers
SOURCE: Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Posted on Jan 31, 2010
There are long axis print voids. Does the print head need to be replaced?
Before replacing your printhead, try cleaning the printer, run the cleaning card and also clean the printhead using the alcohol saturated swab, zebra part number 105909-169. In some cases that will fix your issue, if not your printhead needs to be replaced. If replacing your printhead, please make sure your card stock are clean and don't have sharp edges as that could be the cause for a scratched/burned pixel on the printhead.
-- The Pros at www.DiscountIDStore.com
Sep 22, 2011 | Zebra Eltron P310 Thermal Printer
I need drivers Eltron Zebra P310CM for Windows 7
Hi I solve this problem with a program called CardFive this program provides several drivers inside when you install it in Windows 7. I install CardFive 6.3. Note. this program don´t install a printer driver in Devices and Printers in Windows 7, only provides you a interface to print cards with your Eltron p310 and you can choose other printer models discontinued. My printer interface is parallel and works in Windows 7 With CardFive 6.3 pro.
Jan 14, 2011 | Zebra Eltron P310 Thermal Printer
Jan 21, 2010 | Zebra Eltron P420C Printer
Zebra p330i just says downloading data
The reason in incorrectly established drivers, or in the printer. Better certainly to give to repair.
http://conditioner2009.bravehost.com/
Aug 08, 2009 | Zebra Eltron P310 Thermal Printer
What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work.
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Jul 08, 2009 | Zebra Eltron P310 Thermal Printer
Unable to print a dark green logo?
Use Photoshop. Also their are Color Profiles you can install on you computer. n windows
Rt click an Goto properties/Settings/advanced.
THe last tab is where you can install them.
They will only allow you to match you screen to the printer color better.. Google where and what on you need.
In Card5 id I remember. There should be a setting that comes up when the print is initiated.
You should be able to set card of to control the color and not the printer. Or visa verso.
Also you can get a Solid Resin Green Ribbon.
Selvol
Jun 16, 2009 | Zebra Eltron P310 Thermal Printer
Feedig problem
Make sure your image is only 1 page.
Possibly the printer is printing the second page blank.
I know you are most likely printing a single card.
But some times LARGE fonts or LARGE images will print as 2 Pages.
Check it out.
Let me know.
Regards
May 27, 2009 | Zebra Eltron P310 Thermal Printer
Keeps printing on 1 spot
I am a bit unlear of the QUestion Here.
But let me say it sounds as if it it tring to print in color.
The back and forth motion is what tells me that.
Feb 14, 2009 | Zebra Eltron P310 Thermal Printer
Printing special effects from corel draw on Eltron p310
Nov 15, 2008 | Zebra Eltron P310 Thermal Printer
Eltron p310 + Vista driver
i cant find drives forwindows vista....
Sep 29, 2008 | Zebra Eltron P310 Thermal Printer
Zebra Eltron P310 Thermal Printer Logo
560 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
