Question about Five Star TTN325-BGW Dual Fuel (Electric and Gas) Kitchen Range
How do you light the pilot for the four burners on top?
  • 262 Answers
This machine should have a ignition system when you turn the gas knob.
Make sure you have power to machine. if you do and you turn the know to the light postion and you dont here the clicking noise then it is posible you have a bad spark modual or switch harness or your ignition system is not geting power.
Posted on Sep 08, 2010
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Oven not lighting
Sounds like the ignitor in the oven is weak and not building up enough resistance to the gas valve to allow gas to the burner. I would replace the ignitor if it is more than 3 or 4 yrs. old.
Posted on Oct 05, 2007
ginko
  • 19396 Answers
SOURCE: lighting pilot light on magic chef gas range
Check
HowStuffWorks "How to Repair an Oven: Tips and Guidelines"
Posted on Jul 24, 2008
frcs68
  • 1605 Answers
SOURCE: Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
Posted on May 27, 2009
Treefrog15
  • 127 Answers
SOURCE: One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Posted on Feb 25, 2010
Youtube
Replace the top regulator plate and gasket on the gas valve, the four main burner orifices, and the pilot orifice. You need to remove the main burners to access the orifices and disassemble the pilot assembly to access the pilot orifice.
Jul 25, 2014 | Pitco Frialator Kitchen Appliances -...
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
How do you light the pilot for the flat top section of our Imperial 6 top stove?
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Feb 23, 2010 | Vulcan Kitchen Ranges
I have a model 3110PRW gas range and can not get the pilot lights to light. I am getting gas through as I can light all four burners but the pilots will no ignite. It is set up for propane gas.
Hi on the burners there is a hole where the gas comes out of the burner to light off the pilot is this blocked or are the pilots blocked short pilot flame
Feb 09, 2010 | Magic Chef 31000 Gas Kitchen Range
SF 3000 EWWO how to light pilot
You can raise the top lid of the stove to light the pilot lights for the top burners.
The oven is controlled by a electric glowbar ignitor.
Make sure the cord is plugged into a electrical outlet.
If it is and the oven does not work the glowbar ignitor must be replaced.
Jan 16, 2010 | Ovens
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Five Star TTN325-BGW Dual Fuel (Electric and Gas) Kitchen Range Logo
104 people viewed this question
Top Five Star Kitchen Ranges Experts
Oloyede Monsuru
ray gallant
Tom Chichester
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
