I just purchased my first laptop...and do not like the touchpad...I want a wireless mouse...can I use a wireless mouse without being connected to wireless...in other words can I use a wireless mouse while I'm 'hard wired' connected??
    Problem Solver:
  • 13 Answers
Yes, the mouse most likely uses Bluetooth to communicate with your laptop and is independent of your wired/wireless connection to the internet. The mouse should have come with an adapter that plugs into one of your USB ports. Plug it in and once the drivers load (automatically), your new wireless mouse should be working!
Posted on Sep 08, 2010
How can I get my pointer to click on as it used to
Which operating system you could use the system restore but f its a hrdware fault the fault might return or not be fixed.
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp.
In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Change Touchpad Settings
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad.
Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
Double-click the Control Panel's "Mouse" icon.
Click the Touchpad tab.
This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers.
However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings.
Refer to the "Warnings" section if this applies to your computer. Locate the "Scrolling Settings" area within the touchpad properties tab.
Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes. Change touchpad settings in Mac OS X
Click the Apple menu and then select "Preferences."
Click the "Keyboard & Mouse" icon.
Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Nov 19, 2013 | eMachines E Machines E525 Laptop Computers
I cant get the mouse to connect to my laptop
Desktop or Laptop ?What type of mouse ??...
sign up
Wireless Mouse to Your Computer & Laptop
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace. Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse. If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse.
If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware.
If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
http://www.sunvalleyus.com/Article/LaptopKeyboardInfo/46.html
also
Laptop computers generally have built-in pointing devices such as touch pads that you can use to navigate the operating system on the go.
However, touch pads and pointing sticks are small and generally far from ergonomic.
At home, you might like to connect a full-sized mouse for greater comfort.
Computer mice connect in a variety of ways, and you should be able to find a mouse what works with whatever peripheral ports your laptop has.
As a general rule, any mouse that works with a desktop computer also works with a laptop.Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs.
Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time.
Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard.
Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse.
This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function.
Press and hold the "Fn" button together with the mouse icon button.
Look for the disable/enable symbol that briefly displays on your screen.
Slide your finger over the laptop's mouse and attempt to use it as normal.
Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter."
Press the left arrow key to navigate over to the "Device Settings" tab.
Press the tab key to reach the "Enable" button in this section.
Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box.
Press the space bar to remove the check mark.
Put your finger on the touchpad, and move the pointer down to the "Apply" button.
Click "Apply" to save the settings. Close the mouse "Properties" box.
Press the keyboard "Windows" logo key to open the "Start Menu."
Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart."
Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function.
Open the "Control Panel."
Go to the "Add and Remove" or "Uninstall" programs section.
Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse.
Select the "Uninstall" option to remove any software and settings associated with this secondary mouse.
Restart your computer and attempt to use the built-in laptop mouse as normal.
Check to see if the mouse is working properly.
Press the keyboard's "Windows" button to open the "Start Menu."
Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel."
Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it.
Find "Mice and other pointing devices from the list" and open its "Properties" dialog box.
Select the "Driver" tab and choose "Update Driver."
Allow Windows to search the Internet for drivers and to update them automatically.
Restart your computer after the drivers are updated, and use your mouse as normal.
http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Aug 11, 2013 | Computers & Internet
How to change touchpad settings for lenovo g550, I hate this touchpad, please help
You really can't do much with settings for a touchpad. I would recommend disabling it and using a wireless mouse. var fctb_tool=null; function FCTB_Init_c6f64f985d3644929e3995eea1c55206(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d35d1f3861484992b99b0e9345d90151(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Lenovo G550-29583AU Notebook
Touchpad Doesn't Work And I Need To Connect Without Hardwireing.
Often there is a button along the top of your keypad" f "keys.Look for one with wireless beams on it. Press FN and that button .1stFn then2nd Wireless buttonThat should turn on wireless...Also you could hook up an external mouse
Apr 04, 2010 | Computers & Internet
Mouse pad stopped working on actual laptop but will work when using wireless mouse.
Try uninstalling the touchpad driver from the Device Manager, restart the Computer and reinstall the Touuchpad driver after connecting a wireless mouse.
If the issue persists then this indicates that the issue is with the Touchpad sensor and requires to get the Touchpad serviced.
Dec 01, 2009 | HP Pavilion dv6000z Notebook
Wireless Mouse on a laptop with built inTouchpad on the keyboard
No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
PS I hope its not the batteries
Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Cordless mouse
Just a thought, perhaps you could borrow a usb cable mouse. Tell the comp to detect the wireless mouse, then unplug the usb mouse.
Oct 30, 2008 | Computers & Internet
Mouse/touchpad issues
Try to connect a external mouse.
If it does work ok with the external mouse . It means that their is a problem the touchpad.
Who can take it to a service center for repair or you can use the external mouse.
Thank you
Thewho1
Jun 29, 2008 | Computers & Internet
Wireless mouse?
Try disabling the mousepad on the laptop. sometimes this is what causes the problem. Another reason might be the mouse batteries. If they are running low you might experience problems like that.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
